Previous in Forum: What is retirement?   Next in Forum: HAPPY JULY 4th TO MEMBERS FROM USA
carbondioxide absorption
07/03/2008 1:17 AM
Trees uses carbon dioxide by photosynthesis and gives away oxygen during the day. But at night /absence of light , it absorbs oxygen and gives out carbon dioxide .
What is the net absorption of carbon dioxide/per thousand Sq.m of green leaves, in a place where there is 12 hrs day/12 hrs night ?
Any idea or data on it ?
Re: carbondioxide absorption
07/04/2008 2:13 AM
Carbon takeup is not stored in the leaves, but in wood. Take a tree, look at its mass growth during a certain period of time (say 20 years) and multiply that amount by 44/24
The mass number of C = 12, O = 16, so total of CO2 = 44.
By photosynthesis the tree converts CO2 in C, storing 12 mass units in the wood while releasing O2, being 32 mass units, in the air. The carbon content of a tree is about half its mass, so that explains the figure of (44/12)/2 = 44/24
You might want to take a look at this page:
http://www.plant-trees.org/resources/Calculating%20CO2%20Sequestration%20by%20Trees.pdf
Indeed, trees give of CO2 at night, but as you already mentioned, there is a net uptake and it can be calculated as described above.
Unfortunately, leaves cannot be considered in the uptake calculation as these fall of during autumn and decompose, creating CO2 and other gasses like methane.
Adding to the cooling effect by the CO2 uptake is the efficiency of photosynthesis. About 20% of incoming sunlight is converted into sugars (and wood) and 80% is converted to heat, whereas on other materials like concrete the full 100% of solar energy uptake is converted to heat (and then I left out other effects as reflection etc etc). So there is both a direct and long-term effect of cooling using trees.
I'd recommend to start planting.
"It doesn't matter how beautiful your theory is, it doesn't matter how smart you are. If it doesn't agree with experiment, it's wrong." - Richard Phillips Feynman.
