Previous in Forum: Relationship of Tanker DWT to mooring winch pull and anchor weight   Next in Forum: ss pipe welding
Motor coupling alignments
07/03/2008 1:45 PM
Can anyone explain what a "double radial alignment" is?
Pathfinder Tags: Double radial alignment
Re: Motor coupling alignments
07/07/2008 11:37 AM
Double indicators are used for the alignment.
07/11/2008 1:10 AM
hi,
there are two basic methods for aligning motor with pump,gearbox, etc., one is rim & face method in which one dial indicator pointer positioned on the radial side and the second on the face of the movable machine (motor) coupling to calculate the misalignment. the second method is reverse indicator method in which two dial indicators used to measure only the radial deflections in both (motor and pump) couplings for misalignment calculation.
the reverse indicator method is the precision method of alignment than the former one.
if you search for reverse indicator method in google you will find the entire details.
feedback if you cant.
bye
r.babu
07/11/2008 12:13 PM
I'm familiar with both dial indicator methods.
I have just never heard the reverse dial inicator method called a double radial alignment.
Thank you,
John
Register to Reply 3 comments
jburley (1); ramanathanbabu (1); takle (1)
