Previous in Forum: Is Climate Change the Origin of Civilization?   Next in Forum: Used Photomultipliers - Where are they?
13 comments
Location: Colville up the top of the coromandel peninsula
A possible nano technologe break through in development
09/14/2006 5:26 AM
Hi there Robbie Kleij here,
As I have designed a system for the change over from fossel fuel to EV transportation electrification and communication over the last 18 years the design of a newly developed "wheel form" is avalible for assesment within the nano sphere.
The wheel form is at present under Copywrite and has taken a long time to perfect the design model, altough the criteria of control for electro-magnetics is well under way by many others I have seen within my design that it would be suitable to advance the nano applications in such a way as to have avalible a mechanised elbow capabile of turning greater than 180 degrees and probably ver close to 360 degrees, through both hemispheres, that could potentially be used to connect triangular segment together thus forming a surface that has both electro-magnetic adhearence for use in nano devices and capable of making a nano paste that with all due respect to design would become a self operating medium comparitive to assembly of forms through computerization of the same.
My design of the wheel has within it's form a turbine that operate through the center of the wheels structure and I imangine that with it's use placed in nano technology the turbine would have to be ommited due to component probable linkages that may or may not be required.
For an example: you may end up with a form (shape) of humanoid that when stroked drove the wheel to produce a charge within the surface of the humanoid thus sending a monitered electric flux to be sensed as pleasure or pain whilst all the time the wheel would be part of the humanoids outer and possibly inner surface areas.
With the aiddition of this connection the form could with all potential change shape as easy as the changing of shapes now capable within 3D software such as Autocadd and others. with the assemply relying completely on equalatral triangles as the surfaces main assembly.
The likely hood of this coming to the fore is a very high possibility and I would enjoy disscussion from anyone interested.
your sincerely Robbie kleij (wheel forms for cars is another department)
Thankyou and always - -accentuate the positive,when it's the positive you really need.
Pathfinder Tags: nano technology
United States - Member - New Member Fans of Old Computers - PDP 11 - New Member Hobbies - HAM Radio - New Member
Re: A possible nano technologe break through in development
09/14/2006 8:41 AM
Huh ?
09/14/2006 10:43 AM
I agreee with Steve. Have you been working on nano tech for 18 years?
09/14/2006 11:23 PM
Uh... could you break that down a little more? Maybe it's the insider lingo, but most of that didn't even sound like English. Did you post this through some sort of translator software? I think the theory sounds interesting, but then who could tell?
See Bio for signature line........political correctness and insecure people are such a pain-in-the-ass.
09/15/2006 12:52 AM
Well. I certainly am glad of the other comments.
Totally beyond me!
09/15/2006 4:19 AM
Hi there all,
firstly thankyou for the comments.
This article I wrote is in Copywrite, meaning It's still in development stage.
I therefore can only offer disscussion at present and of course to explain it fully would be folly for I'd be giving away 100% of the design.
the wheel Form or design shape and constrution method is of my own, which I have worked on for 18 + years.
Whilst in the final stage of design I noticed that it would be appliable to other technologies other than "a change over plan to EV's for the transportation" industry.
the main use for this part of the innovation is for connection of small triangular shapes.
the triangles to be conected would connect automaticly through software/firmware (yet to be devised) the only part I have designed is the mechanics of the design.
for an example ( really out on the edge here so use you imagination to it's fullest extent please, as you would with science fiction) although I have designed this to become a real possibility.
1. your car you are driving becomes larger than a standard street car to become a off road vehicle with larger outer dimensions, at this stage only the body can be effectively morphed to another shape with the use of these trianguar connections.
so sorry not the wheel morphing etc.
2. imagine also a pyramidal shape consisting of hundereds if not thousands of flat trianglar parts. the triangulas are connected using my innovations in such a way that the complete pyramid parts are folded close to one an other. each triangle is connected in such a way that they form a equlateral triangle consisting in it's basic form of four surfaces being the four equlateral flats combined with a space (cavity) within the equlateral shape. ( multiplied for the major unit.
The result is a design of structure that can be bent (folded) to accomidate any design that the software allocates. a flat sheet or a square box. any shape that can be obtained from ajoined triangles.
the main idea is to be able to ( to a certian extent) morph the surface into various shapes according to the software settings.
the basic construction in more detail:
A. a triangular sheet of material equiangular in it's outer dimentions ( of any size)
b. the thickness for each triangle sufficent to hold some computerized firmware.
.... so for a standard prototype lets give it dimensions.
z. trianular shape 1 meter by 1 meter by 1 meter to each pointed corner
y. triangular thinkness approximatly 20 to 30 centimeters not more.
x. the outer parameter (edges) of the triangle are chamfered to accomidate folding.
w. at each corner a quarter arc opening to accomidate the connection I have designed
v. at each corner is my connection to allow the units to fold respectively with the other triangles that it connects to.
the design is made capable through the use of slides (attching veins that connect the individual triangles together at each corner such as curved feins resembiling the thinkens of feeler gauge slides that are curved as some times used in robotic claws) and linked to the wheel design that I am using in the original "EV wheel form" to make this all possible.
this mechanization is yet unresolve in science.
the sizing is for demonstation purposes only and would suit much smaller application sizes. ( hence nano technology) and with smaller sizing the whole structure would become far stronger also.
there are still criteria of the attached units to be resolved such as the free floating connections that each structures uses in my design ( the mentioned wheel form)
the problem at present is that some components need a second component to attach to and being triangles there would no dought be need of these extra components at some corners and then at the alternative attached triangle the component that the two triangles are attached with already is avaible from the first triangle thus making the second triangle store the component when it is not nessesary.
I do understand that it's kind of diffuclt to explain and understand a new development without giving it away and that is at present my main difficulty.
I hope this is sufficent for the mean time to arouse discussion.
09/15/2006 5:53 AM
Hi there, what exactly are you trying to solve i.e. what is the current problem or need for this thing you describe, although very interesting, many thanks
09/15/2006 6:15 AM
Thanks for the reply,
I'm just wanting to have the idea put to good use, and it is of no use to me at present.
I am still wanting to make the wheel component for transportation and this project is going no where without somebody that wants folding materials for robotic use or other. I know it's been looked for and just thought it interesting enough to show people that it is avalible.
I could give it away of course, but being a major break through I think it worth at least somthing albeit small or even just recognition.
I have in the past given away ideas which have been used for monetary gain i the automotive industry and for advancements in Yachting which I have more developments avalible for. ( no fun in that if they are not going to mention that I was the initial designer) but dissusion about material coverings that a project such as this can inhance would be worth my consideration to help with inhancements of this kind.
I suppose it's just a learning curve for every one and as my tag say the positive is what counts
09/15/2006 9:51 AM
This is obviously a hoax. I base that on the doublespeak and the exceptionally poor spelling and grammar. It sounds like something that would be presented by Dilbert.
09/15/2006 11:01 AM
thanks GUEST and you where who?
not really a line of thought I want to get in to so bye
09/15/2006 11:12 AM
O so I need to make one thing perfectly clear.. it's in DEVELOPMENT.
if per chance anyone want to discuss it you can contact me direct from my personal web page
http://www.treezone.co.nz/
and for your information I am Dutch by birth and I got 14% in grammer in high school
my tuff luck I suppose, I DO know that the right to be heard does not give me the right to be take seriously but there you have it ......... your choice
and I do have moderator statis on some sites I add to thanks for your indulgence and sorry for my lack of grammer ( stop)
09/15/2006 11:34 AM
Hi there all at cr4,
I've been reading and learning a bit more about he sizing of my threaded item it seems that I'm about 1000 times out (too small) in sizing the design I have here.
it is probably not for the nano sizing it's more to do with micrometers than it has to do with nanometers.
although I'm still on a small scale of product it may be that initially I got it wrong in that sense
09/15/2006 4:22 PM
If you have a paper to present to an international forum at the nanotechnology convention www.nanotx.biz contact me and I'll see if we can get you in. Time is very short.. the convention is in Dallast Texas on Sept 27 & 28.
Joe Veneziano, (469)671-5710
09/15/2006 4:51 PM
thankyou Joe Veneziano,
I will certianly give it my utter best shot to have a white paper ready
althought the time is rather limited as I said it is still in the development stage.
I will contact at your given phone number
as I am in New Zealand I would need to know the location that the phone number is in.
please send the your where abouts to so I can phone you at an appropiate time to.
e mailto:robbiekleij@treezone.co.nz
yours sincerely Robbie Kleij
Register to Reply 13 comments
Anonymous Poster (3); jdst (1); mdbobbo (6); shooter (1); Steve (1); water buffalo (1)
