For a 6" PVC potable water distribution line, which is best, solvent weld or MJ (Mechanical Joint) connections?
Having many years experience with 2" and smaller solvent weld PVC lines, I was thinking it would be best, but my client wants to use MJ connections, because that is what the rest of his system is comprised of.
The MJ connections use a Megalug restraining device that not only compresses an elastomeric wedge or trapezoidal seal around the OD of the PVC, but also has several radial bolts that screw radially inward onto the OD, thus placing a huge frictional force that will prevent the pipe from ever pulling out of the connection. I was surprised to see it does not utilize an insert into the ID to oppose the inward force of the screws, and support the pipe wall.
The MJ connection has the advantage of better handling during assembly because there's no twisting of the pipe. The solvent weld connection is better because there's no corrosion or cathodic protection involved.
I was also surprised to discover C900 PVC pipe, which has yet another set of OD's, wall thicknesses, ID's, and DR's. Why couldn't they've used the IPS series which have been around since they invented pipe?
