Previous in Forum: CABLE SIZE SELECTION   Next in Forum: welding
double deck floating roof tank design
07/12/2008 4:18 AM
How can I check the rotation of double deck floating roof ? I design some double deck floating roof tanks for an oil depot.
thanks
Re: double deck floating roof tank design
04/05/2009 3:58 AM
usually rotation of double deck roof is not allowed and it even rotation is restricted by using anti rotational devices.this is as far as i knew correct me if i am wrong
can u please suggest me how to deciede in between double deck and single deck roofs
04/06/2009 2:22 AM
Thanks for your comment. Usually double deck floating roof is used for obtain more buoyancy. When a pontoon does not provide enough. Then for large diamater tanks (more than 60-70m) we have to use double deck, although I 've designed double deck for even 44 & 34m ID because of client request. Also it is better to use them for small diameter floating roofs (less than 6m)
Mahta
04/23/2009 10:01 AM
thank u
we usually use double deck if dia is >60m or < 12m
and another question is does selection of floating roof depend on
viscosity
specific gravity
flash point
04/30/2009 10:00 AM
Dear Mahta
give ur contact details at daljeet.corrtech@gmail.com
need to discuss ddfr tanks
05/18/2010 8:37 AM
hi, i am working in a construction company, could any one tell me how to design a double deck floating roof for a 72 m dia tank? cant find any reference any where....... deepuranjit@gmail.com
Anonymous Poster (2); dinesh2u85 (2); mahta (1)
You might be interested in: Roof Curbs, Roof and Floor Trusses
