Previous in Forum: crystal osc.   Next in Forum: Troposheric Scatter
clock for uP
07/13/2008 9:21 AM
what are the different modes of clock generation for uP by connecting X1 or X1,X2 pins ?I need explaination of operation.
Re: clock for uP
07/13/2008 11:13 AM
See my answer to the almost identical question you have already asked..
Re: clock for uP
07/14/2008 2:41 PM
A bit more information is necessary.
But back in the old days, a crystal was directly connected to X1 & X2, with capacitors (typically 10pF ceramic) from each lead (X1 & GND / X2 & GND) to ground to help the crystal 'startup' and get to it's resonant frequency.
As for connecting directly to X1, I assume that has to do with driving the clock input of a uP directly. If I remember correctly some (if not most) can be directly driven by a TTL level signal from an external clock generator; and make sure that your driving the correct input. And then again I believe that some wanted their 'own' clock generator.
You need to be aware that some uP's require certain voltage levels, slew rates & frequency's to operate properly.
Bla - de - bla - de - BLA!!! "That's Me!!!"
Re: clock for uP
08/19/2008 7:22 AM
thank you
Register to Reply 3 comments
AH_WA70 (1); user-deleted-1105 (1); Walts_Worker (1)
