Previous in Forum: plastic material   Next in Forum: Global Warming and CO2
Polypropylene Surface Tension Data
09/15/2006 4:35 AM
hi guys
i need polypropylene surface tension data at different temperatures,
thanx alot
by
Re: Polypropylene Surface Tension Data
09/15/2006 11:42 AM
The easy way to get it is to write to a manufacturer and ask for the data. The other way is to calculate it. I checked my Perry's Chemical Engineer's Handbook for the equation, but it barely addresses polymers, I need to get a newer version. I performed an internet search for the equation and it turned up some interesting sites. It turns out the equation is more involved than most would want to get into. Try the search for yourself, hope you like differential equations. You did not mention a range of temperatures either.
09/15/2006 3:10 PM
thanx shooter but could you please give me the name of the equation (scientific name), this will make it easier to me.
and also i dont know how to make use of the surface energy data i found about pp,
if you can help me i will be thankful
Good Answers: 120
09/15/2006 11:13 PM
read this, search from there
http://www.csu.edu/chemistryandphysics/csuphysvan/participantactivities/Kondratko.FengertHS.ContactAngleIFTWetting.pdf#search=%22Polypropylene%20%2B%22wetting%20angle%22%22
Per Ardua Ad Astra
09/18/2006 11:58 AM
There is no scientific name for the equation. The names of the persons that contributed to the development of the equations as listed in the Perry's are, Jasper, Brock and Bird, then modified by Miller, and for hydrogen bonded materials Macleod originally suggested an approach that was further developed by Sugden. What temperatures are you looking for? Do you have access to a Perry's? Or can I send you more info?
Register to Reply 4 comments
aurizon (1); kik0kik0 (1); shooter (2)
