I was wondering, what do standards say on this issue?
I am designing a tabletop machine (pneumatic press) that hot-stamps labels onto small plastic parts about the size of pencils. The operator manually feeds one part on a holder/bed and then presses a pedal to activate the following pneumatically actuated (very fast) sequence:
1. Bed moves transversly by 30mm and places itself under the labeling press.
2. Press stamps part (about 250deg C at stamping location), then retracts.
3. Bed retracts to repeat cycle.
So far the safety design was minimal, so it was possible for someone to stick a hand where they shouldn't.
I have designed a full enclosure (with appropriate ventilation), leaving just enough room for the operator's hands to feed the parts, making it impossible to penetrate further or touch anything else, and also implemented an optical sensor fail-safe, so that phase #1 cannot start if the hands are not fully retracted. This should also reduce the heat radiated on the operator and the noise from the pneumatics, which is considerable...
I am getting some 'heat' from the industrialisation dept, claiming that so much safety is redundant (and expensive) and have no access to safety standards to make a solid case (sadly, safety beyond standards is not acceptable, it seems). Any feedback, preferably with refs., will help greatly.
