Previous in Forum: BS 65001.Part 1:2000 or ISO 10380   Next in Forum: Flushing pump sizing for turbulent flow
Componants/materials needed for recycling bin
07/14/2008 5:28 AM
Hi Everyone
Thanks so much for all your help, I got 77%, so quite happy, for those who didn't read my first request. I am doing a degree Open University Innovation: designing for a sustainable future.
I now have a drawing, so now have to suss out componants and materials,who I obtain them from. The main bin is made from stainless steel ( I know some of you said not to use, however I need something that will last be sustainable and chic, so won't date) and the removable units will be made from PET. The lids have a push release mechanism. What I need to show for this next part is the process of obtaining componants and the material and doing a costing as well.
Is there anyone out there that can help again please.
Many thanks in advance
Kate
Good Answers: 101
Re: Componants/materials needed for recycling bin
07/14/2008 11:04 PM
Stainless steel is very expensive. It is also very hard and heavy, making cutting and machining it difficult. Finally, it requires the use of costly argon welding to join the pieces together. Why not use UV-stabilized medium-density polyethylene instead? It is cheap, lightweight, has good tensile strength, is highly chemical resistant, and can easily fabricated by a plastic-molding factory. In fact, it is often used to produce refuse bins. You could also use glass fiber-reinforced plastic, but it will cost more. It will still be much cheaper than SS though.
However, if you still want to use SS, go for SS304, which has good corrosion resistance and is much cheaper than SS316. Calculate the amount of material you need, then check with a supplier how much it will cost. Check with a metalwork plant how much it will cost to cut and weld the pieces together. Add up all these costs, then you have a good idea what your total cost will be.
Remember to mark it up if you're thinking of commercializing it.
