Previous in Forum: CFM FOR 6" BORE CYL WITH 50" STROKE   Next in Forum: What grade of steel to be used ............
pneumatic tube length
07/14/2008 2:28 PM
please tell me if my two pne. cylinder getting supply from same electromagnetic coil is there need to keep same length of inlet and outlet tube to get same time stroke. because my cylinders are operating one pusher. the problem is both of them are not going reverse and forward same time.
thoughts becomes things.
Pathfinder Tags: pneumatic
Re: pneumatic tube length
07/14/2008 6:09 PM
Line length must be the same to both Cap Ports while lines to the Rod Ports can be a different length than Cap Port lines but equal length to both Rod Ports from valve.
The other problem I have encountered is when a cylinder is stroked completely to either end they can get stuck and not take off immediately when flow enters the ports. This can be overcome by mechaniclly stopping the cylinders before they bottom out metal to metal. This condition is most noticeable when the cylinders are oiled excessively.
Bud Trinkel
07/16/2008 4:42 AM
i m very much convinced with ur ans. now let me know is it necessary that discharge flow at elecropneumatic valve (silencer side) suppose to be same. i feel that there is variation is it necessary to change it
07/15/2008 12:43 AM
your cly is same brand , if same brand ,you check pressure,i think that pressure very in application
07/15/2008 5:16 AM
Ideally it should be the same however, if it can't be avoided that they have different lengths, you could install speed control valves in ports of both cylinders then fine tune/adjust until they have the same timing.
"It is only when we die that we become Immortal."
Register to Reply 4 comments
Anonymous Poster (1); BudT (1); High Lander (1); sandeep lokhande (1)
You might be interested in: Hydraulic Cylinders, Air Cylinders, Rodless Cylinders
