I need to figure out the size of compressor required for my application. The compressed air will be used as carrier gas in the GC at 15 psi and it will also be used to clear the gas line (1/4" diameter tube, 200 feet length) at 40 psi pressure every 1 hour. The compressor output will be appx 40 psi, we will reduce it down to 15 psi for GC. The 40 psi will go to a valve which will be open for say, 15 secs to clear the line then close - repeat this every one hour.
for first part uses appx 0.07 SCFM.
for second part, I think to clear gas line i will need (tube ID) * pi * length of tube = 13.08 cubic feet of air within 15 secs at 40 psi pressure. If we dont take pressure ino account i would need 13.08/.25 = 52.32 CFM. how to incooperate pressure into the calculations - may be just divide by pressure.
This application would be running 24/7 for weeks to months and i need to use oil-free air compressor. I dnt want it to be running (ON) all the time. I can add large capacity tank to the compressor. how do i calculate tank size, duty cycle of compressor, ON time of compressor with tank etc? Thanks
