Previous in Forum: Bad gas?   Next in Forum: Looking for US company that produces vehicle lug nuts
8 comments
Caterpillar 3512 Fuel
07/19/2008 3:05 AM
At present we are using Industrial Diesel for our Caterpillar 3512 generator. Is this the best fuel for our equipment? Kindly send me information and details. Ty!
User-tagged by 5 users
Re: Caterpillar 3512 Fuel
07/20/2008 2:28 AM
Hi
Clean industrial diesel yes dirty no...and most is dirty so you need to clean it.is your genset prime or stand by what consumption are you getting p/h....many questions still need to be asked.
tell us more
Bad things happen WHEN GOOD MEN DO NOTHING..GOOD MEN STAND UP
07/20/2008 3:11 AM
Kindly report to your CAT representative or look to the CAT manual and you will find out the recommendation of manufacturer and compare the requirements to the specifications of your "insdustrial fuel".
07/20/2008 10:58 AM
Yes, I agree. An engine of this sophistication demands only the range of fuels as recommended by the CAT man
gem
07/20/2008 11:20 AM
I am not familiar with the term "Industrial Diesel Fuel". WHat is it exactly?
If it is a fuel that meets ASTM D975, it is acceptable for use.
If it is Heavy Fuel Oil (HFO), Residual Fuel, or Blended Fuel, it is not acceptable in Cat engines.
The best fuel has a high cetane, low API gravity, high lubricity,low sulfur, low gums & resins, low water & sediment, and low pour point.
You need to check your manual for the API gravity required for your engine. Most say between 30 & 45. Your engine was probably bench tested at 35. You will get more btu's (power) at the lower number. In other words, you will get more for your money.
The lubricity varies considerably from load to load. The more lubricity the better. There is only 1 fuel additive available that will give you the best lubricity available and meet all 7 "Premium Fuel" requirements; Diesel Treat 2000 by Schaeffer Manufacturing. Many of the lubricity enhancers actiually remove lubricity from the fuel, making it more detrimental to your fuel pump and injectors. An independent web-based blog (thedieselplace.com)confirmed this with independent testing of all the major fuel additives last year.
Give me a call if you need more info @ 216-401-1845.
THEOILGUY55
Engineering Fields - Piping Design Engineering - New Member Technical Fields - Architecture - New Member
07/20/2008 11:23 PM
Caterpillar has published High speed diesel specifications for the engines manufactured by them you can call your nearest CAT dealer who will answer your query in the light of EPA and EU emission regulations you need to use the fuel that matches fuel specified by Caterpillar what ever the engine model or Else you may end up costly replacement of fuel injection system of your 3512 engine.in addition violating emission standards of your country i have the cat specs but might be out dated hence this advice
crm
Run silent run deep
10/27/2009 9:52 AM
I have worked in the diesel fuel injection industry for years and the greatest damage to injectors is contaminated fuel or fuel with high sulphur content. The injection pressures these days are high to atomize fuel and improve emission. Any dirt that gets through diesel filters is potentially harmful.
11/25/2008 2:15 PM
diesel fuel degrades with time 26% in 28 days!!!!!! If you store diesel fuel in your genset without maintaning your fuel you are bound to have problems!!! you can call CamVacUSA for all your diesel fuel reconditioning needs: 1-877-822 FUEL
Good Answers: 16
07/24/2009 10:07 AM
Start by having a compitent fluid sampling lab check your "industrial diesel". Who ever is doing your oil samples can do this. Then refer to Cat publications to see if you are in spec.
Anonymous Poster (1); crm (1); Diesel_Parts (1); flegelo (1); Georgee (1); reconman (1); THEOILGUY55 (1); Tim in Mexico (1)
You might be interested in: Fuel Testers, Fuel Cells, Fuel Additives
