Previous in Forum: BDV and IFT,Acidity,tandelta of transformer oil related.   Next in Forum: thin set
10 comments
Clay bars
07/20/2008 12:24 AM
Today I used a clay bar to polish the paint on my Toyota. This clay worked great. My question. What is this material and is there a cheap source for this. Mothers wax gets a arm for the amount you get.
Popular Science - Cosmology - New Member Popular Science - Paleontology - New Member Popular Science - Weaponology - New Member Popular Science - Evolution - New Member Popular Science - Genetics - New Member Popular Science - Biology - New Member
Location: The Nevernever as much as possible, Earth when I have no choice.
Good Answers: 11
Re: Clay bars
07/20/2008 11:23 PM
Left Coast Bill, Turtle wax makes a good product also. Try Walmart for the other manufacturers. As for the material, I have never taken the time to research it, but I will and I will get back to you.
Dragon
Ignorance is the beginning of knowledge. Heresy is the beginning of wisdom. The ignorant heretic is the wisest of all.
Good Answers: 120
Re: Clay bars
07/20/2008 11:25 PM
clay is a fine abrasive, Al2O3, alundum, in the pure state.
To get fine clay mix it in water, really high intensity mixing. Let it settle for 2 minutes and pour the murky water off to settle overnight. On the bottom of this you will get fine clay, and you can do this again. Industrially they use a centrifuge to settle in a second. In addition, they can get varied mesh grades, 600 to 2000 mesh or more.
There are places that sell the fine clay online, but it must be grit free.
http://www.google.com/search?hl=en&safe=off&q=polish+%2Bwax+%2Bclay&btnG=Search
Per Ardua Ad Astra
Good Answers: 11
Re: Clay bars
07/20/2008 11:27 PM
Aurizon, Good Answer. I had not had any reason to research before this.
Dragon
Good Answers: 94
Re: Clay bars
07/21/2008 8:09 AM
Is there really clay in the clay bars? Some places describe the same product as 'putty'. It starts off as a fairly hard block which you have to knead before use to make it softer, thereafter it resembles a stiff putty. It is mildly abrasive & smoothes out the minor imperfections in the paint surface whilst also lifting off contaminants, it has to be used in conjunction with a suitable cleaning fluid. the finished surface is much smoother, almost glassy & gives a much deeper shine.
Good Answers: 120
Re: Clay bars
07/21/2008 8:48 AM
It looks like they may take the dry clay and add an oil to make a heavy paste.
The paste acts as a pad and delivers submicron scratches = polishing. Any hard bits work into the clay.
Has anyone tried to see if they are oil or water based?
Per Ardua Ad Astra
Good Answers: 94
Re: Clay bars
07/21/2008 9:10 AM
I have some at home, I could see if it mixes with water.
Good Answers: 94
Re: Clay bars
07/22/2008 4:54 PM
OK, I can now report that the clay does not mix with water, it seems to have no effect. It will mix with a light oil, this makes the clay a little softer. The clay will dissolve in thinners. Does this help?
Good Answers: 120
Re: Clay bars
07/22/2008 5:03 PM
Yes, It must be oil based. So dried clay is mixed into oil until you get the right consistency. They use roller mills for this task. Raw material cost is low. All the cost is in the milling and sieveing the clay to be fine enough to not scratch.
Per Ardua Ad Astra
Good Answers: 94
Re: Clay bars
07/23/2008 4:35 AM
Agreed, I should have mentioned that the clay bar I have is made by Meguiars, other brands may be different. I noticed that, when dissolving, the clay still feels smooth- not at all gritty.
Re: Clay bars
07/21/2008 9:38 AM
Might be a synthetic clay product as it is used with water based cleaners that would render "clay" into soup.
ONE TEST IS WORTH A THOUSAND EXPERT OPINIONS
Register to Reply 10 comments
aurizon (3); Dragonsfarm (2); erssk (1); Nigh (4)
