Dear Friends,
My obective behind the following query is that I need to confirm exact match of the replaced motor and how can I reduce energy consumption of this motor for same load.
I had one machine with original Dietz make motor 15KW 350v 32Amps 66Hz 1910rpm.Now this motor was replaced by someone in past with Siemens 18.5Kw 415v 32Amps 50Hz 1450rpm.Motors are driven by Siemens Midimaster drive.
On load the motor is normally running above its rated speed i.e above 50Hz ( 60-65Hz range ).
I have doubt regarding the exact match between these two motors. I mean, Is the motor replaced correctly ( I guess not because second motor torque will get reduced at 60-65Hz ).
Is there any motor matching exactly same to the original one?.OR Can I use a 2 pole motor but don't know what KW rating to use.
I would like to operate this motor in constant torque mode so that the energy consumed by this motor on load will get reduced ( I hope I am correct ).
