Previous in Forum: Arching horn and Corona Ring   Next in Forum: Where fuses melt
distribution transformer11kv/400v
07/22/2008 2:17 PM
how to maintan secondary voltage (400v).
i haven problam ...
primary 11kv (matured kv)but tap connected to 11.825kv, but secondary voltege is 385v metured (no load), we need secondary 400v,tap provition available 10.175kv,10.450kv,10.725kv,11kv,11275kv,11.550kv,11.825kv.if change the tap setting from 11.825kv to 11kv possible ket 400v?
Re: distribution transformer11kv/400v
07/22/2008 3:50 PM
if you connect it to the 11kv tap you'll get 414v on the secondary
if you connect it to the 11.275kv tap you'll get 404v which is the closest you could get
07/22/2008 4:32 PM
Do you have to have exactly 400 volts at no load? Is your transformer rated at
11 kv/400 kv? No way to know from the information you provided. Connect to the
11 kv tap and take measurements. You may want the voltage a little higher to help
with voltage drop. You also need to be concerned about how well the utility maintains
the 11 kv voltage.
Good Answers: 73
07/22/2008 9:48 PM
You may have another "problam..." such as disconnecting yourself from the very high voltage. If you don't know the answer to this question you have no business messing around with the tap.
Of course we may never know if you were successful........
07/24/2008 12:39 PM
Anonymous Poster (1); Lendog (1); NotUrOrdinaryJoe (1); wareagle (1)
