Previous in Forum: Effect of airlock in hydrostatic test   Next in Forum: which is better direct drive or belt drive
8 comments
Pumping water in small quantities
07/22/2008 3:34 PM
Hi: I have a problem with my air conditioner (I am using it to get hot air, we are in winter here) due to it is working as a heat pump, so it is condensing water outside. Therefore, a continuous dropping is taking place on the path and my neighbor complaint.
I have thought about gathering the water in a container and by means of a pump, to send it two floors upwards, near place where I have a drain. The quantity is very small, about a quart per hour.
In a nut, I am needing a small pump (and cheap) to send this water approximately six yard in upwards direction. What kind of pump must be? Any advice?
Thanks in advance.
Gabriel, Buenos Aires, Argentina
Pathfinder Tags: air conditioning water pump
Re: Pumping water in small quantities
07/22/2008 4:54 PM
07/23/2008 1:19 AM
I'm not sure if they can lift that far or not, but fountain pumps (for decorative waterfalls) are about as cheap as you can get. If one can't do it, I'm sure two could (first one pumping into a container that supplies the second) and I suspect two fountain pumps will still be significantly cheaper than a single industrial pump.
You will also want either a sensor (float or weight-operated switch) or a timer to ensure the motor does not run for long periods with no water to pump.
Is freezing a concern in BA? I suspect it is only rarely a problem.
07/23/2008 6:49 PM
"Is freezing a concern in BA? I suspect it is only rarely a problem."
Hi:
No, very cold weather in winter here means not less than 5 ºC
07/23/2008 6:55 PM
" but fountain pumps (for decorative waterfalls)"
Hi: I´ll consider that pumps. Thanks a lot.
Gabriel
07/23/2008 2:53 AM
Collect the water in a 5gall tank the use a small submersible with an integral float switch, this will pump when there is liquid and shut down when there isn't.
07/23/2008 4:43 AM
Hi Gabriel,
Have you considered to use a commercially available condensate pump - also known as condensate lifting unit? It consists of a small container collecting the fluid, a level sensor and a small pump. For more information please refer to : http://www.wilo.com/cps/rde/xchg/en/layout.xsl/3525.htm
Regards
nudnik
07/23/2008 12:39 PM
The easiest and cheapest solution would be to attach a hose or downspout (drain pipe) and run it down to a place where it won't discharge water across the path below such as a garden, somebodys flower pots, or an outdoor drain. If this is a possibility it's a lot better and ceaper than pumping it upward. If you must pump upward, I like the fountain pump idea - cheap and not a lot of power consumption. Use floats to turn them on and off.
Of course there is always the option of putting an awning over the path to catch the water so it drips down on the far side, keeping the path and passers by dry.
United States - Member - New Member Engineering Fields - Chemical Engineering - New Member
07/23/2008 9:42 PM
This sounds like the KISS principle in action, I vote for this one.
Money doesn't talk, it screams in your face.
Register to Reply 8 comments
Anonymous Poster (1); betomachine (1); dkwarner (1); Gabriel (1); Kilowatt0 (1); nudnik (1); PhysicsProf (1); Roy The Boy (1)
