Brains trust,
I have a small VVVF drive that supplies a 4 KW oil pump. The problem is that when the unit is stopped via an emergency stop (removing the supply voltage) it then requires a start in manual to get the unit running again.
I sussepct that crashing the VVVF drive is causing either a over or under voltage state on the bus volts protection.
My question is, will placing a resistor in the bus circuit slow down the change in volts enough to allow normal restarting.
Any feedback would be appreciated
