Previous in Forum: EDM Texture (VDI 3400 / 36)   Next in Forum: material camber
PVC Extrusion shape deformation
08/01/2008 12:38 AM
Hi
today i met problem in my pvc cave type pipe parts reached my industry it shape deformed
this is Extrusion process of PVC pipe and it length is 2m width is 230mm
what is the reason to change the shape?
how to correct this problem
Regards
Dinesh
India
dinesh
Re: PVC Extrusion shape deformation
08/01/2008 3:48 AM
Maybe you should take measure to make it deformed back.
Professional Manufacturer for Plastic Sheet Extrusion Equipment from China
08/01/2008 3:54 AM
I cant understand sir
Please tell why this happen and how to prevent it
Regards
Dinesh
India
dinesh
08/01/2008 4:33 AM
We need more infor mation. If it isn't delivered to drawing it's the suppliers problem surely.
Maybe the design is wrong with inadequate cross section...maybe it wasn't cooled properly as it left the extruder....maybe it's too soft a material..or not the material specified.
You need to provide LOTS more information to a sensible answer.
The real answer to the question 'How to correct this problem' is..
Understand the processes involved...
Solving problems is easy...the hard part is determining what the problem is.
08/01/2008 5:13 AM
Hi
yes i am also thing cooling problem
This is the PVC material rectangular hollow hight 110mm width235mm thickness 3
can you tell me at what cooling temp maintain and also heater temp,vaccum pressure
dinesh
08/01/2008 5:16 AM
I have no idea...this is not my field of expertise..I just have a broad wealth of engineering knowledge/experience/common sense .
08/01/2008 5:36 AM
ITs ok sir thanks for your information
It is help my further step
Regards
Dinesh
India
dinesh
Register to Reply 6 comments
dinesh.ar (3); extruder-machinery (1); user-deleted-1105 (2)
