Previous in Forum: material camber   Next in Forum: ISO9000 revision 2005
9 comments
Horsepower Test for a 9.9Hp Outboard Engine
08/01/2008 2:52 PM
I work in a lab and have been given a 9.9hp outboard boat motor. The customer, he has built this engine himself, has asked us to confirm the horsepower. In other words, he states the engine is 9.9hp and I need to provide proof (data) that it is indeed a 9.9hp motor.
Does anyone know a company that can dyno test it for me or if there is a software package that I can buy? I have about $3000 to complete this project. I am located in Toronto Canada.
Regards,
Two silk worms had a race. They ended up in a tie.
Pathfinder Tags: boat engine horsepower Outboard
Re: Horsepower Test for a 9.9Hp Outboard Engine
08/01/2008 4:21 PM
Borrow 9.9 horses, hook up a chain and pull the other way:
Location: Milky Way galaxy, Sol solar system, Earth (not Giaha), USA, WA, N.E.
08/01/2008 5:01 PM
I googled 'dyno testing' and came up with www.revsearch.com . This looks like a possible fit.
They that do not learn from history and apply those lessons to the present are bound to repeat its failures.
Good Answers: 247
08/02/2008 2:32 AM
9.9 hp engines are peculiar in that they are really supposed to be less than 10 hp, so they can be used on lakes with hp restrictions. Measuring to 1 percent reliably and repeatably with an average dyno is not all that easy. You may need to research a little (or perhaps your customer knows) how 9.9 engines are certified (or if the regulating authorities take it on faith that they are really less than 10 hp).
The measurement itself could be pretty easy. You could replace the prop with a disc brake and a reaction arm, or with a hydraulic pump (torque being directly related to pressure) and accurately measure the torque and rpm. Driving an electric motor (as a generator) is another option: you'd need about 7.5 kw of load and a possibly a water tank to absorb the heat. With a DC motor, the amperage is directly related to torque.
RPM can be measured easily and very accurately by many devices you are probably already familiar with. Torque is not quite as simple to do accurately, but a load cell on a reaction arm is probably a good bet (or less directly, current or pressure).
Of course, if you find someone already set up to do this, they would be able to run a power curve in less than an hour's time. That would be quick, cheap, but less fun than making your own dyno. The standard chassis dynos found all around the country for cars and motorcycles are not well-suited for outboard motors.
Depending on accuracy required, a very simple method is to put the motor on a test tank and measure thrust against a known 9.9 using the same prop pitch and diameter. (This assumes the two engines are similar in characteristics, though.)
Just as simple: put it on a boat, measure the boat's top speed, and then do the same with a known 9.9. This would be close enough for marketing purposes but not for legal requirements.
The owner has no doubt warned you to be darn sure you provide water for cooling.
Popular Science - Weaponology - Scapolie, new member.
08/02/2008 5:27 AM
Hi Ken,
I used to build swinging arm dynamometers to test my model steam engines and full size stirling engines, they are by far the most simple method of getting a very accurate measurement! They are also very easy to construct, much simpler than a water brake.
The arm has to be graded accurately to get the best results to give ft/lbs, and the maths is quite simple.
Spencer.
Good Answers: 247
08/02/2008 2:37 PM
I agree.
Perhaps the most fun, though, would be to bolt a mountain bike wheel/tire to the prop spline, get the thing zinging along, and then press the tire against the ground, a little like using an oversized chain saw. Mount two handles a convenient distance apart, and equip one with a scale...
What could be better? Tire smoke, noise, danger...
08/04/2008 12:34 PM
...the lights and siren on the way to the hospital, the first-hand look at a crack EMT team in action, yeah, y'can't beat THAT for excitement, huh, Ken?!?
08/02/2008 7:12 AM
Take it to a Harley Davidson Motocycle shop most have a Dyno machine.
Good Answers: 247
08/02/2008 2:28 PM
I've designed and built a couple of these motorcycle dynos. The difficulty, for testing an outboard motor, is that these are chassis dynos, and building an adapter to go from the prop spline to the wheel rollers, a means for supporting the motor while it runs, and a means to provide water cooling without interfering with that adapter is a project somewhat more time consuming than building a dyno from scratch. Measuring rpm is simple. Measuring torque can be as simple as bolting up a car-sized disc brake and measuring the force against a reaction arm which can bear directly on the motor's housing, with load cell between. Easy, fun project that can be done for far less than $3000 - unless the PO is charging a lot for his time. If so, then he should take or ship the motor to a facility that is set up for testing outboard motors, such as one that owns one of these.
If such a facility charges more than $100/hr for dyno time, I'd scream "highway robbery!" (After all, you can rent a car of higher value than the dyno for a whole day for $49.)
08/02/2008 3:58 PM
yEAH i just figured the motorcycle shop could tell him where one was for a boat motor.
Register to Reply 9 comments
Blink (3); dadw5boys (2); dbdwoods (1); EnviroMan (1); Scapolie (1); Shadetree (1)
