Previous in Forum: 10 Foot Aluminum Pole Dropped Down Soil Stack Vent   Next in Forum: Gasket
gate valv or globe valve
08/01/2008 3:04 PM
Which valve is most suitable gatevalve or globe valve in condensation steam traps
Re: gate valv or globe valve
08/01/2008 7:24 PM
The gate valve is normally used because it permits
full flow when open and tight shut off
when in closed position. It facilitates
repairing or servicing traps, pumps and
other equipment.
08/02/2008 5:33 PM
The gate Valve are normally used but gate valves are lesser leak proof after 6months. and also throttling also difficult. better use globe valves
08/04/2008 4:10 PM
If the gate valves are exercised and its of good quality they will work fine, there is no need to throttle the condensate that's what the steam trap does. Globe valves as previously stated are for throttling, a good application/example of this would be on a bypass for a Pressure Reducing Station. Also Globes are typically more expensive and larger in physical size.
Anonymous Poster (1); pipeit (1); shogun7 (1)
