Previous in Forum: vector group   Next in Forum: isolating switch
Transformer operation question
08/02/2008 7:03 PM
The primary winding of a transformer consists of two parts:
1- Primary leakage inductance Lp1
2-Primary coupling inductance L1
neglect the wiring resistance.
So the total primary inductance Lp=Lp1 + L1
The voltage across L1 must be constnat all the time = N1*d@m/dt
where @m is the mutual magnetizing flux, which is constant for all loads.
Now,if the primary is connected into a constant AC supply voltage V1 and the secondary is connected into resistive load,then:
V1 = Lp1*d i1/dt + N1*d@m/dt
V1 and N1*d@m/dt are constants while the first term of the equation Lp1*d i1/dt
is variable depends on the primary current !
Any one can explain that conflict in the equation ?
Thanks
Re: Transformer operation question
08/03/2008 12:18 AM
To begin with, you have neglected the induced secondary inductance eg. Z=cos i di/dt.
08/03/2008 12:27 AM
Could you please explain with further details.
is i the primary current ?
Register to Reply 2 comments
