Previous in Forum: DIN Vs ANSI   Next in Forum: Gas turbine exhaust Insulation
work execution plan/strategy to retube high pressure boiler
08/04/2008 11:03 AM
we are to repair a high pressure boiler; i need a work execution plan for retubing of this high pressure boiler
Re: work execution plan/strategy to retube high pressure boiler
08/04/2008 4:25 PM
WOW!!!! That is quite the question ...............
I don 't have the time to give a complete answer, HOWEVER .........
Please be sure to hydrotest the boiler upon completion
08/04/2008 4:50 PM
Alright, I have a little time to provide and hopefully steer you in the right direction-
It seems from your question that you are lacking the most basic/fundamental knowledge regarding boiler repairs. My first piece of advice would be to hire a competent engineer/consultant/contractor to help you with this endeavor.
Apart from that - you must first specify what type of boiler, pressure rating, and size.
From there the issues you must address include:
  1. Applicable code to which boiler was manufactured/to be repaired (for example to AMSE BPVC Sec 1)
  2. Safety issues including vessel isolation/lock-out and if confined space entries must be done
  3. Proper materials for the replacement tubes (see applicable code) and proper certification for these materials
  4. Proper qualified workers/contractors (for example certified to National Board 'R')
  5. Proper welding procedures (dependent on materials and design)
  6. Proper heat treating of weldments (pre/post heat)
  7. Inspection/NDT of all repairs (including, but not limited to MPI/LPI, and X-ray requirements)
  8. Proper documentation of all repairs (including, but not limited to mill certs for materials, welding procedures, welder qualification card records, NDT results)
  9. Finally a hydrotest of the boiler (typically at 1.5 x design pressure) to ensure repairs are sound
Hopefully this provides a little insight into your predicament.
India - Member - Gandhigiri
08/15/2008 10:39 AM
you have to contact boiler manufacturer.
10/09/2009 9:54 AM
Recommend that you contact the following company - www.limburns.co.uk
