Previous in Forum: samerkok66   Next in Forum: Supercritical Boiler
welding
08/05/2008 3:05 AM
in gas welding, y oxygen has 40psi pressure and acetylene has 10 psi pressure
Re: welding
08/05/2008 3:14 AM
And?
Good Answers: 15
Re: welding
08/05/2008 6:35 AM
you need to google the oxygen/acetylene welding process.
but basically, it takes a lot of oxygen to mix with a little acetylene for the process.
AND more importantly, the acetylene is unstable at pressures above 15 PSIG.
if you were to slice open an acetylene tank, you would find the inside filled with a spongy material, wet with acetone, which absorbs acetylene and keeps it in suspension untill needed.
here is a page to start you off.
If you don't have time to do it right the first time, when are you going to have time to do it over?
Good Answers: 266
Re: welding
08/05/2008 8:24 AM
In gas welding the pressures of oxygen to acetylene are usually equal but vary with tip size. Recommended pressures are listed by the manufacture of the torch.
Anonymous Poster (1); charlie_r (1); ozzb (1)
