Previous in Forum: help   Next in Forum: Should accessibility be made a requirement?
Sulfuric acid storage tank maintenance
08/07/2008 10:15 AM
I am seeking a procedure for cleaning a sulfuric acid bulk storage tank. I have an NDT method available but am lacking a technique to safely and effectively removing the sludge buildup that has collected over the years.
There is probably an established procedure to do this. Can anyone help out?
FS
Pathfinder Tags: sulfuric acid bulk storage
Re: Sulfuric acid storage tank maintenance
08/08/2008 12:24 AM
Assuming that your tank is unlined mild steel - see this site
NOTE: Make sure as much acid is out of the tank as possible BEFORE you add water. Adding water to acid is not a good idea -
  1. It generates heat and the water can boil
  2. Puts the concentrated acid into a highly corrosive state
    1. Explosive hydrogen is formed when mild steel corrodes
08/08/2008 2:18 AM
Thanks , good answer !!!
07/08/2011 9:36 AM
Hi Did you manage to find a procedure for the removal of sulphuric acid sludge from bulk storage tanks. We are facing the same problem?
Can anybody else help
Register to Reply 3 comments
Anonymous Poster (1); Kathryn James (1); sivaprasad (1)
