Previous in Forum: difference between eeprom & Flash   Next in Forum: What software and hardware do I need?
20 comments
New Technique For Residual Stress Measurement NDT
08/07/2008 2:09 PM
\crt\crt4.bmpNEW TECHNIQE FOR RESIDUAL STRESS MEASUREMENT NDT
p.i. Ennio Curto
TECHNICAL DESCRIPTION
Preface:
For internal stresses are considered: 1) Strains to which the materials are submitted and calculated. 2) Residual stresses of material due to heat treatment or forging, welding, etc. The equipment measure all stress types than equilibrate themselves in the surface of the material, and in a relatively large volume sometimes the same order of entire structures, these stresses are within the elastic metal field and have a spatial orientation, triaxial.
Theory:
Oscillations elastic (also called vibration) in an elastic material, consist in alternately movement around the respective equilibrium positions of the elementary masses, cause of these movements generate a conversion of potential energy into kinetic energy. This phenomenon occurs due to reactions (elastic forces) that the elementary masses, above views, opposed to elastic movements, these reactions are proportional for the Hooke law to the displacement. The elastic waves produced, propagate themselves with a fixed speed, which depends on how quickly the masses elementary enter into oscillation. The elastic waves of this type are called 'permanent progressive, which spreads to a constant speed is absolutely independent of the speed by which the elementary masses move during their oscillation, and hence the respective accelerations. Is easily to verify that the oscillations of material point P. (on which suppose concentrated elementary mass m.) are harmonics. In any instant the elastic force, applies to P, is proportional to distance x from its position of equilibrium 0, the acceleration of P (for proportionality between the forces and the corresponding accelerations), this has occurred in harmonious motion. The impulse creates in a metal mass a harmonic oscillation (vibration), characterized by a specific frequency and displacement (movement of its mass) acceleration and speed.
This wave is longitudinal, when the direction of vibration is the same motion of point P, or transversal, in both cases the resulting values were identical, the only difference is a delay of 1 / 4 phase.
Elastic energy, as subordinate to a impulse energy, is:
Ei = Ek + Ed + Ep
Ei = Impulse energy Ek = Kinetic energy
Ed = elastic deformation energy Ep = plastic deformation energy
Ed = ½ K dx² = ½ m ω² dx² = Ed = ½ m X dx
K = constant elastic material (stiffness)
dx = displacement Ẍ = acceleration Ẋ = speed ν = frequency
Behaviour elastic metals, due to new discovery:
Technique
The tester, through accelerometer mounted with magnetic base, gives the value of acceleration of the vibrations generated by the impact device with constant energy, on metal. The acceleration value combination with other parameters gives the exact value of residual stress or loads applied at the point tested. This value is displayed in the LCD directly in N/mm². For non-magnetic metal, will be using wax or gel to attach the accelerometer at the metal. The application of this non-destructive method, gives the opportunity to measure the residual stress in every surface point and more time. It is very easy to use, efficient and allows for the measurement of residual stress in welded elements, and existing structures, for all types of metals with NDT method.
Residual stresses specifications.
The residual stress in a metal doesn't depend on its hardness, but from the module of elasticity or Young module and from its chemical composition.
The hardness of a metal indicates its ability to absorb energy elastic, plastic or kinetic energy, but through it not possible to determine the value of residual stress. In a metal with the same hardness we will have different values of this stress. Therefore, the problem will be to measure the values that vary so exactly proportional to the residual stress values in a given metal.
The residual stresses tend to equilibrate themselves in the surface of the material.
The measurement made with all the major methods, X-ray, string gauge (destructive), optical etc. the residual stress is determined between the measuring the displacement of the equilibrium point the reticule crystalline.
The method discovered analyzes the value of frequency and vibratory acceleration generated by an impulse to constant energy with the subsequent reaction elastic (elastic field) from the metal. The equipment don't recognize the value of compression from that of tensile stress. It gives the value of the space resulting or volume but with the applying of a triaxial accelerometer we can have forces values axis x, y, z.
Effective for welding, hardened treatments, vessels control, bridges, pipes line, aeronautics, NDT inspection for every metal types.
Ennio Curto
Good Answers: 40
Re: New Technique For Residual Stress Measurement NDT
08/08/2008 9:41 AM
Fascinating, Ennio ~ Was this your own work, or are you sharing an 'encounter'?
I am curious as to whether this particular work has been published yet, as in Materials Evaluation, ASNT's monthly periodical...or an overseas counterpart(?)
There are numerous applications for this test method. In this particular format, what are the capabilities: e.g., lowest sensitivity yet measured, smallest physical size testable, 'range' throughout a larger test object, etc? Limitations or restrictions imposed by the test environment, if any?
Best Regards ~
08/09/2008 9:41 AM
Dear, ndt tom
The accuracy of this technique depend from the surface condition. (e. g roughness, homogeneous nature of the material, not superficial hardened) is normal ±8%
The others specifications depend from the material type or support.
Regards Ennio.
Spain - Member - New Member Engineering Fields - Nuclear Engineering - New Member
Good Answers: 25
08/11/2008 5:15 PM
To define the stress field (applied or residual) in a surface of a metal (simplest case) you need to determine three parameters: the two main stresses (maximum and minimum) and the direction of any of them (they are orthogonal).
The stress field may vary through thickness (even usually it's considered maximum at one surface) and of course may vary across the whole surface.
You are taking about "elastic waves". Of course this can be longitudinal, transverse, surface, etc, depending on the incident angle of the mechanical impact and the surface. The speed of propagation is well known, it's called the sound speed which depends on the "constant elastic material (stiffness)" more known as the elastic modulus, Young's modulus, etc. for longitudinal waves or the shear/transverse elastic modulus for transverse waves. In fact, the elastic constants of a material can be determined by measuring wave propagation speed. Any book on ultrasonics can give you the exact formulae.
When the wave is introduced in the material, all material vibrates according to the corresponding frequency and the wave can propagate through all volume.
Having this in mind. How can the 3 parameters be measured in one specific point if the behaviour of the wave depends on the stress field on all the part?
Kind regards
08/12/2008 4:55 AM
We still use x-ry or ultrasonic to measure this stress at present.
now somebody begines to use russia tech of megnetic field to do the job.
Ei = Ek + Ed + Ep
Ed+Ep is total potential energy. and Ei is total energy.or +some heat energy is a well-known formula. why is new discovery?
Its out of my depth. but I suggest you can present your product by taken part in this world NDT conference hold in Shanghai this Autumn.
08/12/2008 5:48 AM
Dear Join.
It is need to complete
dx = displacement Ẍ = acceleration Ẋ = speed ν = frequency afther there is the discovery,
Best regards Ennio Curto.
08/12/2008 9:58 PM
Hi,
What are you on earth speaking?
I cannt understand.
Why dont call k as elestricity coefficient directly? even high school textbook can be found this.
what is the last part meaning?
ω dx = 1 ? so that Ed = ½ m X dx?
we know dF= -k * dx but what is m * dx?
what is the below box meaning?
08/13/2008 4:46 AM
This a big question cnpower........
Regards Ennio Curto
08/13/2008 6:17 AM
maybe.
I forget all, I may go over it.
now I guess that stiffness may equal to rigidity.
just curious, I hope to know this big question.
ω = angular veiocity? m = mass?
what is m * dx?
08/28/2008 10:13 AM
ah, I made a misake. sorry, I regarded the X as a multiplex sign.
½ m X dx
08/14/2008 12:12 AM
I was happened to visit an instrument factory of my firend which manufacture residual stress measure gauge last month. they showed me their product and how to use. its based on Prague angle equation. a part of the instrument is illustrated as follow,
it widely use in important projects in china. It costs about 72 thousands dallows.
It can be used for any material
Good Answers: 183
08/23/2008 7:52 AM
If I understand correctly your description your system quantifies the hysteresis of the part. You assume that the loop depends in its surface on the residual stresses. What do you do when residual stresses are not related to plastic deformations and the overall behaviour is for the whole material still totally elastic? Do you consider that because the strain level the area of the loop will change? I would very much appreciate a more detailed explanation.
Thanks in advance.
08/25/2008 7:32 AM
Dear Guru But you must excuse me I have a little difficult to explain to you, as my knowledge of English very poor, I must therefore support to a automatic translator. I say you that new technique based precisely the residual stresses measurement in the metal elastic fired.
(See text). Best Regars. Ennio Curto
Good Answers: 183
08/25/2008 9:43 AM
Quite surprising the other texts were in much better English. Have you changed the translator for this only answer?
I have the feeling (which may be wrong) that your language is Italian. You may send the answer in Italian since it is a language I pretty well understand. Of course if my question was for you clear enough. If necessary I am willing to explain with more details what I think.
08/25/2008 10:56 AM
Dear Niki Name (guru)
I see. you are a very science man specialize in FEA (finite element analysis)one system for residual stress evaluation.You should like to know the new discovery, but this is not patentable discovery because is one physical Principia's not one idea, and after 10 year of research you understand why I don't say this revolutionary discovery in the residual stress field.
Best regards
Ennio Curto.
Good Answers: 183
08/26/2008 9:38 AM
My question has nothing to do with FEA although you are right in the assumption that I work with such simulating soft. I appreciate that out of a sudden you English became better. You make wonderful progresses.
OK, keep your secret and enjoy the success if you find the right financial support. Be any way careful since too often the money is not for the one who had the idea.
If you will need any kind of help use the personnal message channel.
Good Answers: 183
08/26/2008 1:00 PM
"Ed = ½ K dx² = ½ m ω² dx² = Ed = ½ m X dx"
I am sorry to make a remark concerning above series of equations: the dimension of a mechanical energy is [ FL].
K is a stiffness with dimension [F/L] so that the 1st relation is correct the result being [F/L]*L²= FL
Dimension of M is [M]= F*T²/L, of [ω]=T^-1 so that the second relation has as result F*T²/L*T-2*L²= FL and is again correct.
The 3rd relation is m*X*dx which leeds to F*T²/L*L²= F*L*T² and is not any more correct ! I presume this is only a writing error you wrote X in stead of X' which should have the dimension L*T-1.
Please correct me if I am wrong.
Regards
NickName
08/27/2008 4:31 AM
Dear Nick name ,you have reason to say that the money is not all, sure if the research regarded of new drugs for the health I would not make a secret and I would not want to make to pay the patent license like the druggist industries, you understands to me. This my discovery can only damage the big Companies of the field or who is legacy to existing technologies, than I assure to you are not poor, and to facilitate who work in a field which that one of the controls and structural safety, with smaller costs and facility of application. In my case therefore not there are ethical problems, on the contrary. Regarding the formulas the error has had to the writing in the site and to different utilizing symbols.
Regards Ennio
03/10/2013 11:55 AM
Verify new technology for residual stress measurement NDT
I would like to get in touch with accredited Laboratories, University Centres Research Institutes, for to propose the measurement of residual stresses NDT, which have the following instrumentation:
IEPE Accelerometer 10 mV/g sensibility.with magnetic base
Data acquisition (DAQ IEPE USB) and relative Software for vibrations measure .
Impact device D (as accessory) is possible to buy on China market (low price ).
I will supply, all free, the indications to measure the value of the residual stresses in a type of steel. All this for verify this new technique.
You can see on this website my profile and to find my E-mail address.
Thank you very much for your collaboration..
Ennio Curto .
p.i. Indust. Vicenza
Good Answers: 183
03/10/2013 5:05 PM
I had a look and noticed the fact that your information doc has been deleted!
I think that you have in Italy not far from your place such labs you are not far from Milano and there is a very good university there if you do not want to come intouch with italian universities you are not far from austria and switzerland so other opportunities are open to you (ETH Zurich, Ecole de Lausanne) and many other. It would be better to get a contact near to home.
03/10/2013 7:38 PM
I've done in my tests questii Citte and at the Université of Beijing with positive results, I would not be in this forum.Ora I just want to give an opportunity to all accredited Laboratories, research centers of Universities, research centers equipped in order to let the world know that the new system of measurement of residual stresses NDT.
Honestly this as soon time should be introduced in the market the portable system, which I assure you is very practical. easy to handle and of low cost. (much depend on this type of experimentation).
Thank you for your interest
I greet you cordially.
Ennio Curto.
Reply to Forum Thread 20 comments
Anonymous Poster (6); cnpower (5); ennio curto (2); Kwetz (1); ndt-tom (1); nick name (5)
