Previous in Forum: belt conveyor and roller   Next in Forum: specific heat of air at constant pressure
NPSH
08/09/2008 6:28 AM
Dear friends
For a centrifugal pump to be installed a height of 4m above the sump water having atmospheric pressure (open sump) of 1bar, what is the likely NPSHactual assuming a vapour pressure of 1m and total suction loss of 1m. What should be the NPSHrequired for specifying to supplier
Re: NPSH
08/09/2008 12:48 PM
NPSH available (for suction lift situation) =
NPSHa = Absolute Press. - Vapor Press - Line Loss - Difference in Elevation.
So for your case ..........
NPSHA = 10.2 m - 1 m - 1 m - 4 m = 4.2 meter
NOTE: NPSH available MUST be greater that NSPH required by the pump.
Typically you want a safety factor of 1.2 so tell your supplier to give you a pump with NPSH required of 3.5 meters or less.
Re: NPSH
08/09/2008 4:44 PM
can i get detail information for selection of pump
on any site of pump manufacture or any way.
thoughts becomes things.
Re: NPSH
08/10/2008 12:40 AM
I just stumbled across another really good site with a book for download:
http://www.lightmypump.com/pump_book.htm
Re: NPSH
08/10/2008 4:47 PM
how can i select expansion joint or non rigid coupling.
it is recommended that a pipe anchor be installed between it and the pump.
what is this pipe anchor?
Re: NPSH
08/10/2008 7:15 PM
It would probably be best to start a new thread on this topic, but, oh well - here goes:
  1. In order to select an expansion joint, or non-rigid coupling you need to know through stress analysis (see below) what displacements your pipe system is experiencing (axial/lateral/angular).
  2. A pipe anchor would be recommended in between to ensure that no excessive loads are transmitted through the piping to the pump. Stress on the pump leads to premature bearing/sealing failure. An example of a simple, rigid pipe anchor would be to weld on sufficiently strong lugs to your pipe and anchor bolt them into concrete.
  3. There is one mind-set of maintenance/piping design that it is best to avoid the use of expansion joints/non-rigid couplings because they can be a headache/prone to failure and leaking. You avoid there use through proper piping design by adding enough flexibility into your system.
  4. Piping stress analysis is an art/engineering field itself and should be done to the applicable code. Much too big of a topic to do it justice here. These days computer software such as Coade's Caesar are used for the design. Smaller systems can still be done by hand, but more complex systems are best left to computers.
