Previous in Forum: electric control system..   Next in Forum: need training!!!!
control system lab
08/12/2008 8:26 PM
this is my lab experiment result.hope someone can guide me to solve it.
1. set the scale on the attenuator unit to zero.set the switch on the operational amplifier unit to the 100k resistor.
2switch on the power supplly and if the motor rotates continously, vary the zero set on the operational amplifier unit until the motor stop.
3.vary the scale on the attenuator unit so that the motor speed is at 1000rpm.
4.input voltage 276v
motor speed-brake scale
970-10
980-8
900-4
980-2
1000-0
the question is
1.calculate the percentage regulation for the brake setting at scale 9.
2. explain why the motor does not stop when the input voltage is zero.
this is an experiment of closed loop speed control system.
Re: control system lab
08/14/2008 11:22 PM
I run a website devoted to controls (http://wikis.ControlTheoryPro.com). I also run a forum (http://forums.ControlTheoryPro.com) related to the wiki where you can ask questions like this if you want another option.
That said I need more info before I could help you. A block diagram of the system under control would be a lot of help.
Gabe
