Previous in Forum: Regarding low cost robot   Next in Forum: magnets
Plastic injection machine
08/13/2008 3:41 AM
Do you know web adres or company about plastic injection machine cooling system e.g. die and oil.
Re: Plastic injection machine
08/13/2008 7:06 AM
Just "google" the manufacturer's name for the machine that you have seen. For each brand of the machines, they are each slightly different.
For temperature control of tooling, most of the machine suppliers also recommend "cooling" or "hot water" units that match their machine types.
Try manufacturers like "JOHNS", "BOY", "KAWAGUCHI", "ARBURG", "ENGEL". They are the ones that I'm familiar with.
08/13/2008 10:16 AM
thank for your relation
08/14/2008 9:52 AM
I blieve you are looking for what is called Die Heaters, ut there re many names:
Try these sites:
http://google2.cancom.com/search?client=immalm-cos&site=immalm-cos&output=xml_no_dtd&proxystylesheet=immalm-cos&filter=0&q=mold+cooling
http://google2.cancom.com/search?client=immalm-cos&site=immalm-cos&output=xml_no_dtd&proxystylesheet=immalm-cos&filter=0&q=mold+circulators
If this doesn't get you what you need then go to this sie and plug in another search criteria:
http://www.immalmanac.com/dir/
Good luck
08/14/2008 1:55 PM
thanks for your interest
08/14/2008 2:41 PM
Visit these folks. I use their equipment and it's very reliable.
http://www.advantageengineering.com/temperatureControllers/SKLE/skleGeneral.php
08/14/2008 10:58 PM
I do not know of the coolers/heat exchangers, but I can say that if you were to change hydraulic fluid to Schaeffer, the temperature would drop 10-20%.
Was your injection machine ever running cooler, or are you replacing an existing heat exchanger.
Call me if I can be a help.
216-401-1845
THEOILGUY55
Register to Reply 6 comments
alperr125 (1); Anonymous Poster (2); Just an Engineer (1); THEOILGUY55 (1); ttressler (1)
