Previous in Forum: Tensioning & Torquing   Next in Forum: Pressure Vessel/Heat Exchangers (ASME Sect VIII, Div 1)
pipe fittings material selection
08/13/2008 2:45 PM
i need to know that when we select a pipe fitting like elbow..how do we select the material and codes applicable...like can B16.47 sr.B flange be joined with mss sp44 elbow ,,,
Location: South East of Las Vegas just far enough to see the lights but far enough to not hear the coins falling
Re: pipe fittings material selection
08/14/2008 12:09 AM
Purchase fittings and pipe that are all the same material after you figure out the best material for the application...........or tell us the rest of the story to get some real help.
Mike
Rule number one; Never ask a question unless you are prepared for an answer that you may not like.
Good Answers: 68
08/14/2008 3:27 AM
Hello quiinces: I think you refer to Weld-Neck and Blind Flange Black Steel Pipe. I am not sure why you would want to mix the types? But if you look at the info on #3 and #1 and 2 below it should be clearer. 1 http://www.pipedata.com/pdp_search.htm....... >mss sp44 elbow 2 http://www.pipedata.com/source=googleads&gclid=CLvE29_djJUCFQpYQgoddBMLfw.......> sr.B flange
3 http://www.pipedata.com/02_psp/faq1.htm.......>Some really useful info' here on sizes, wieghts etc.
4 www.easychinasupply.com/producttrade/last_pt_sel/653603.html
5 http://pngis.net/standards/details.asp?StandardID=MSS+SP-44%3A1996.......> You may find this useful also.
stay safe
babybear
Good Answers: 68
08/14/2008 3:29 AM
Hello again quiinces:
I forgot to mention the pipe standards (as you listed) are the same World-Wide.
babybear
Register to Reply 3 comments
