Previous in Forum: Required solutions to prevent Asteroid-Earth collision   Next in Forum: cut and configura styrofoam
moisture sensor
08/14/2008 9:27 PM
what is the circuit diagram of moisture sensor
Safety - Hazmat - Environmental, Safety & Health Manager Hobbies - Musician - Theremin (That about says it all...)
Good Answers: 19
Re: moisture sensor
08/15/2008 11:48 AM
Guest,
Your question is a little vague...
Are you looking to measure moisture in the air (i.e., relative or absolute humidity/dew point), or in a solid material (e.g., wood, concrete, soil, etc.) ?
Different types of sensors and technologies are used - and can use differences in impedence (resistance), capacitance, or thermal conductivity to measure the moisture...
Re: moisture sensor
08/15/2008 1:18 PM
Wheatstone bridge
Good Answers: 183
Re: moisture sensor
08/23/2008 8:01 AM
- current sensing
- feed back resistor of op amp = gain changing
- frequency change
all based on resistance changes de to humidity.
Good Answers: 243
Re: moisture sensor
08/19/2008 8:04 PM
I made one out of a spring clothespin, two wires, and an aspirin tablet to turn on my pool pump while i was having my sump pump rebuilt.
water dissolves aspirin, clothespin closes circuit, turning on sump pump and ringing a bell to tell me to go turn off the pump.
I thought it was cool.
wife thought I was to use a del the cat term "daft"
but it worked!
milo
Milo (1); nick name (1); The JMAN (1); vicini (1)
You might be interested in: Circuit Breakers, Moisture Meters, Circuit Tracers
