Previous in Forum: Cost Comparison: Diesel and Heating Oil vs. Gasoline   Next in Forum: Olympics Highlight - 50M Shooting Program
15 comments
Refractories - Crushed Firebricks and Portland Cement
08/17/2008 5:42 AM
is crushed firebricks and portland cement mixture a good refractory material?
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
Re: Refractories - Crushed Firebricks and Portland Cement
08/17/2008 11:06 AM
No. At much over 400F to 500F it will probably blow apart.
Make up a small batch and test it, wear safety glasses.
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
08/17/2008 12:40 PM
if i have crushed firebricks then, what could i use to this mixture to line a furnace?
Good Answers: 73
08/17/2008 1:39 PM
There's nothing you can use crushed firebrick for, except perhaps a hearth lining.
A better option is to go with a blanket type insulation. Overall, less expensive that brick, with greater insulating properties.
http://materials.globalspec.com/datasheets/4194/LITIndustries/16E15BDA-64E0-42DE-9D96-D317463AC538
Location: Somewhere in the hills of Pennsylvania, I think.
08/18/2008 12:24 AM
Sodium silicate, chopped fiberglass or rock wool, and your crushed firebrick. You'll have to experiment with the quantities of each and the mix of particle size on the crushed firebrick. Chopped fiberglass is used to reinforce concrete shapes when extreme structural strength is not needed such as in flower pots, benches, garden decorations, etc., even burial vaults. Stay away from Portland cement in the mix. It tends to spall at elevated temperatures. Anyway, I would not use this mixture for temperatures much greater than 500F without a lot of testing.
You might also talk with some pottery people about using thick slip as the binder for your crushed firebrick.
For furnace lining, there are quite a few castable refractories available from industrial suppliers.
I'm somewhere between the age of thirty-something and Alzheimer's. I just can't remember where!
08/17/2008 11:04 PM
Mixing the crushed firebrick would be a bad idea. It would be a self defeating action.
I would love to hear if you have a lot of the crushed refractory.
You can use the crushed brick as filler with several binders and have excellent firebrick or sprayable liner.
Below are several binders that would be good choices
MgPo4
MgChl2
Alkalai activated alumino-silicate
Sodium silicate based binders.
There are more but I would rally need to know more about what the parameters are you are trying to meet.
08/18/2008 2:14 AM
well,i have a large bag full of the stuff.
i was hoping to use it in a mixture to line a homemade furnace with minimal cost/ expendature involved...
but by the sound of things, its not such a good idea afterall :(
Good Answers: 73
08/18/2008 8:40 AM
How big is your furnace and at what temp.? There may be other ways for very little or no money.
08/18/2008 10:29 AM
Crushed fire brick can be used as aggregate in aluminite concrete. 309 or 310 stainless steel needles can be used as re-enforcement.
United States - Member - Technical Fields - Education - Hobbies - Hunting - Popular Science - Weaponology -
08/18/2008 4:01 PM
I have read that when firebricks are made they use crushed fire-clay and crushed reject firebricks...called grog. That is then mixed with fire-clay and fired again making the firebricks.
Could you mix your bag of grog with fire-clay and then fire the furnace slowly to fire the fire-clay mixture?
David A Goodman
08/19/2008 10:11 AM
well, i have the drum ready together with a wooden former for the inside of the furnace, but all i need is a mixture that would withstand plus minus 1500*C. i was hoping that by combining portland cement and crushed firebricks i could make this mixture... what do you guys reckon?
Good Answers: 73
08/19/2008 11:59 AM
1500C! That is VERY hot! What fuel do you plan to use to acquire such temperatures?
Why not check with local scrap dealers for a source of used firebrick.
08/19/2008 12:20 PM
Indeed...I glossed over that thinking 1500 F...
David A Goodman
08/19/2008 12:18 PM
Here's a neat site that might give you some ideas on refractories.
http://www.backyardmetalcasting.com/
By the way, if you are making a foundry, I'm really jealous! I have wanted to make a foundry for a while, but more essential projects always seem to get in the way...roofing the house, tiling the bathroom...
Check your local brick yard for fire-clay mixes.
David A Goodman
08/19/2008 12:52 PM
Mix your grog with refractory cement and use this to fill in and cover your fire brick lining.
Test your system first and take precautions.
Harbison-Walker NO 36 REFRACTORY CEMENT is good to 3200F.
But the help of some one who builds high heat furnaces is recommended.
Brad
08/20/2008 7:45 AM
thanks for everyones input. i know now
for certain plain portland cement in the mix
definately wont work.
thanks again.
Reply to Forum Thread 15 comments
Anonymous Poster (4); Bricktop (4); DAG (3); davlamb (1); FKIA (1); tesla-was-right (1); U V (1)
