Previous in Forum: IC chip also 3D stereo!!!   Next in Forum: some info of jeu thermal uses and underground temp
Selecting Fans for an Air Duct System
08/17/2008 5:51 AM
Good day. I just want to ask, what are the things to be considered in fan selection for an air duct system aside from air flowrate? sorry for the noob question. I'm currently taking BS in Mechanical Engineering and designing a centralized airconditioning system is one of our projects. I would gladly appreciate it if you could help me.
Pathfinder Tags: airconditioning system HVAC
Good Answers: 56
Re: Selecting Fans for an Air Duct System
08/18/2008 12:16 AM
I won't attempt to make specific suggestions as I do not know enougth about moving air thru ductwork.
Over the years however, those system I have experience with were friendlier to end users when they had large diameter fans moving slowly as opposed to smaller fans spinning faster. Air volume was the same, but the big fans were lots quieter and apparently needed less power.
The other trick the HVAC guys mentioned was to size the ductwork as the air moved downstream so the air velocty remained constant.
Perhaps others with a better understanding of this environment can explain why.
L. J.
"Both the revolutionary and the creative individual are perpetual juveniles. The revolutionary does not grow up because he cannot grow, while the creative individual cannot grow up because he keeps growing." Eric Hoffer
08/18/2008 10:59 PM
You need lots of data - look over the attached site it should be of good use to you.
http://www.greenheck.com/pdf/fans/FanFundamentalsMay2005.pdf
There may be no stupid questions - Some are just poorly contrived !
08/18/2008 11:59 PM
Go to the Library and get a copy of ASHRAE handbook (There are 4 of them but I cannot remember whether it is Fundamental or System).
You just need to calculate the total pressure drop of the ductwork and the air flow rate folllowign the step in the handbook. Then find a fan to suit.
Good Luck.
08/19/2008 12:05 AM
My last comment did not go through.
Just go to the Library and get a copy of ASHRAE handbook (ther are 4 of them but I forget whether it is Fundamental or System). Follow the step and calculate the total pressure drop (static and velocity). Together with the air flow rate, select a fan form the catalogue to suit.
Good Luck.
08/19/2008 8:24 AM
thanks everyone. ok i'll do that.
Anonymous Poster (2); eusoj (1); Laughing Jaguar (1); philroth (1)
