Previous in Forum: Flow Through Pipe   Next in Forum: pump capacity and flow
plate heat exchangers
08/17/2008 11:54 AM
how often should gaskets of plate heat exchanger be replaced ?
Re: plate heat exchangers
08/17/2008 1:55 PM
The short answers are:
  1. if they don't leak, don't replace them
  2. it is general practice that whenever gasket surfaces are taken apart that a new gasket is put in place
Now, for the hard part: what type/material of gasket should you be using, well that can't be answered with the lack of information.
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
08/18/2008 1:48 AM
Hello Kyehia
The rule of thumb is:
- if the plate heat exchanger is open for inspection or maintenance is recommended to replace the gasket set to ensure a new cycle of operation.
Hope this help
Look over to the next challenge
08/18/2008 3:27 AM
Yes it helps; it is exactly what I wanted to make sure of.
Thanks Aurel.
K. Yehia
Register to Reply 3 comments
