Previous in Forum: How to Invent a Telescope   Next in Forum: Free Access to Royal Society Archives Includes Newton, Boyle, Others
How Much Heat is Required to Cook Beans?
09/25/2006 8:27 AM
Over the years I have realised that Big-eyed brown beans require lesser heat to be cooked compared to small-eyed brown beans? Could anybody explains this occurence?
Re: How Much Heat is Required to Cook Beans?
09/25/2006 9:11 AM
Actually in cooking beans, it really isn't the heat per say, but the time in which you cook them. Certain beans require up to 6 hours, while others only require 5 minutes.
The harder the and thicker the shells, the longer the ime required.
I generally use the same temp. @ around 350*F for electric, and a medium flame on gas, once they are brought to a boil. Boiling point is at ~212*F, onc ethe boiling point is active, just turn down the heat to low boil and give a minimum time of 3 to 4 hours. Do not add salt untl the last ten minutes of your cooking time. I usually use a couple ham hocks and add an asortment of spices during the cook.
Good cooking.
