Previous in Forum: depressurizing   Next in Forum: unbleached pulp production from the digesters in a paper plant
Rust free blackening on mild steel plates?
08/23/2008 8:14 AM
Hi,
Here i am stuck up with blackening on mild steel plate of 12 mm thickness. We are giving mild steel base plate to outside vendors for blackening. Since we are very close to see shore, the plates get rusted very fast after blackening it.
Powder coating also will not work for my application 'cause it will produce scratches and come off when I slide bigger jobs on the surface of plate.
The basic requirement is I needed a black surface on mild steel plate with non corrosive properties. The reason behind to have black surface is, our's is laser machine, and the black surface aids to avoid light scattering.
Thanks!
Ruban J.
Pathfinder Tags: Blackening on mild steel
Good Answers: 243
Re: Rust free blackening on mild steel plates?
08/23/2008 8:41 PM
you said:"Powder coating also will not work for my application 'cause it will produce scratches and come off when I slide bigger jobs on the surface of plate."
Same with black oxide.
milo
08/24/2008 6:32 AM
Have @ 1 time used 'black chrome' was a very nice satin black & wear was like 'hard chrome'.
Be prepared to dig deep into your purse.
08/23/2008 11:14 PM
Try these guys
www.bearcoat.com
08/24/2008 7:50 AM
Have you tried blueing them, you can get a bluing kit from a sporting goods store that sells guns.
08/24/2008 9:25 AM
Krylon
08/25/2008 10:34 AM
POR-15...you need an angle grinder to get the stuff off
10/15/2008 1:24 PM
If you research gun blacking recipes you will get some ideas. One recipe is to coat with olive oil and burn til black.
Register to Reply 7 comments
Anonymous Poster (4); Milo (1); raggededgge (1); rdavis (1)
