Previous in Forum: Need Web Sit for Phase Diagrams   Next in Forum: Ammonium Sulphate
boiler TDS
08/25/2008 5:36 PM
What can i do to reduce TDS problem of boiler
make - wellman
capacity - 10 ton
thoughts becomes things.
Re: boiler TDS
08/25/2008 5:43 PM
As boiler feed water evaporates in a boiler to produce steam, dissovled solids accumulate in the liquid holding. This is remedied by frequent blowdown of a portion of the condensate in liquid holding and bringing in fresh boiler feed water makeup.
The blowdown frequency is usually controlled by TDS levels and conductivity and should be optimized to operate at efficient levels since the blowdown condensate is at boiler temperature while makeup is much much lower.
Re: boiler TDS
08/25/2008 5:47 PM
This site may help you
Register to Reply 2 comments
