Previous in Forum: basic electrical engg   Next in Forum: Lenze Variable Speed Drive (VSD) internals
10 comments
BUSBAR
08/28/2008 10:58 AM
HELLO PLEASE ADVISE WHAT CALCULATION FOR SELECT BUSBAR
Good Answers: 15
Re: BUSBAR
08/28/2008 11:08 AM
We have seen this question many times on CR4. Please try searching previous posts.
Sharkles
Re: BUSBAR
08/28/2008 1:00 PM
I DO NOT FIND ANSWER IN SEARCH
Re: BUSBAR
08/28/2008 3:02 PM
YOU DID NOT LOOK PROPERLY! I have answered this question numerous times myself, so I KNOW the answer is in there. Please look again.
Re: BUSBAR
08/28/2008 3:06 PM
PLEASE ADVICE ANSWER QUESTION ONE MORE
Good Answers: 42
Re: BUSBAR
08/28/2008 4:54 PM
The forum thread cam up on 05/13/2008 . You could have seen it if you have searched properly.
See my reply to it below and read aall other replies :-
The size of the bus bar for electrical panel is based on the rated current and short circuit current. The configuration , orientation,Clarence of bus bar , single or multi busbars and ambient temperature are other factors. The current carrying capacity of the bus bar will depend on heat dissipating capacity of the bus bar chamber and depends on horizontal or vertical orientation. The size of the bus bar are also decided by the skin effect and Proximity effect( when multi bus bars are used) of the conductor and the metal used (that is copper bus bar or the aluminium bus bar).The bus bar manufacturers normally provide the capacity rating for various standard sizes . It is for the designer to select the correct size and configuration.
The design of bus bar is highly technical job and needs through knowledge. Better consult a competent consultant as it is not the job of armature."
Re: BUSBAR
08/28/2008 4:55 PM
I googled "bus bar ampacity" and the first hit answered your question. A little effort on your part will reap great returns from the vast knowledge on this forum. I am a believer that your should sign in as a member instead of a guest. It makes the post more personal.
Re: BUSBAR
08/28/2008 5:03 PM
I AM WILL WELD MANY COPPER WIRES TOGETHER TO FORM BUSBAR HOW MANY WIRES WILL I NEED.PLEASE ADVISE.
Re: BUSBAR
08/28/2008 8:57 PM
That would be a waste of time and material. If your load is as large as you seem to indicate all you need to do is determine the amp load and go to the site I listed and pick the size of the bus bar. Its that simple.
Re: BUSBAR
09/01/2008 3:18 PM
I seriously advise against this for safety, practical and regulatory reasons.
Search the CR4 website for titles containing "busbar", "bus bar", etc
Re: BUSBAR
08/29/2008 3:49 AM
Anonymous Poster (4); jack of all trades (2); Sharkles (1); V.I.Abraham (1); wareagle (2)
