Previous in Forum: Hot Lap-Top   Next in Forum: USB web cam
Image sensor programming
08/30/2008 2:32 AM
dear sirs
I want to devolop a programme to read some codes with a PIC connected with a web camera. please explaine me how to get D+ , D- signal in to PIC. and what are these two pin.
thanks
Pathfinder Tags: web camera programming
Re: Image sensor programming
08/31/2008 10:22 AM
A lot of info right here:
http://en.wikipedia.org/wiki/USB
Bill H.
09/02/2008 3:36 PM
Dear mfdo,
Which device are u using? Is it compatible with USB?
At a minimum u must use 16C745/65 which is compatible with usb1.0 or 18f2550/4550 which is compatible with usb 2.0.
In addition u must load suitable firmware to the device initially.
It would be better you search the Microchip site with a phrase "USB" and i'm sure you will find many info about usb and firmwares and of course, about the pins will be used since the device is selected.
good luck
Register to Reply 2 comments
