Previous in Forum: std ISO corner cotainer   Next in Forum: reed switches application
Maintenance
08/30/2008 6:56 AM
Any body give some solution to get details of Preventive Maintenance of Conventional Lathe , Milling, CNC, Grinding machine & industrial oven.
thanks.
by,
surya.
Re: Maintenance
08/30/2008 11:17 PM
Calibrate each machine in compliance with an ISO standard, and keep those data as reference. Then periodically recalibrate the machines noting changes in these data until each one fails. An analysis of the data after each failure usually show a marker that portends the failure which you can then use in the future as a diagnostic indicator. This should work because I was once in this sort of business.
I hope that this is helpful
EditorGBAnalysts - Give a boy fish and he will eat may be for a day, but teach him how to fish and he will eat everyday.
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
Re: Maintenance
09/05/2008 4:38 AM
A good way is to follow up the recommendations from operation manual for each equipment.
Look over to the next challenge
