Previous in Forum: air flow calculation   Next in Forum: transformer terminal connection
Lightning Impulse on Transformer
08/31/2008 3:15 AM
Why all transformers are tested by NEGETIVE(-) Impulse rather than POSITIVE(+)Impulse?
Re: Lightning Impulse on Transformer
09/12/2008 10:46 AM
What I know is that oil breakdown voltage under negative polarity impulse is always higher than for positive impulse. This means, transformer should be subjected to a higher level of voltage if tested with negative impulse. But, this is only IEC's approach. Some other standards use both positive and negative impulse for OIL filled transformers. Also check this article: http://www2.nynas.com/naph/start/article.cfm?Art_ID=756&Sec_ID=55
