Previous in Forum: Reciprocating Compressor Valves Reliability   Next in Forum: question on the drawng number in PDM
diff between lead screw and feed rod of a lathe
09/02/2008 9:46 AM
what is the diffrence between lead screw and feed rod of a lathe?
Popular Science - Weaponology - Aerospace nut Hobbies - Musician - music enriches the soul United States - Member - Happy to be from the USA Engineering Fields - Acoustical Engineering - Pro Audio Speaker Designer Engineering Fields - Manufacturing Engineering - Aerospace ME Engineering Fields - Aerospace Engineering - Airplane nut from aeromodels to 747's
Re: diff between lead screw and feed rod of a lathe
09/02/2008 10:04 AM
The lead screw is used for threading, the feed rod is for general machining. The feed rod runs much slower than the lead screw for finer feeds.
The internal gearing is different so that they give different feed ratios to the carriage. This is why they are locked out from one another on the machine. If both are engaged simultaneously the gear box or carriage drive will reduce themselves to bits.
The early bird gets the worm, but what about the early worm? A.E. Neuman
Reply to Forum Thread
