Previous in Forum: "Sequestering" Carbon Dioxide   Next in Forum: Book-list for High-school Boys
hydrogen sources
09/05/2008 11:10 AM
Hello.I recently had the information that some species of alga's could be used as a source to produce hydrogen.
I would like to know if this is indeed true, and were to find some more information on this subject (but usable one, like what sub type of alga's can be used , they origin, were to find them)
all for now!
electronick
“For no man can forbid the spark nor tell whence it may come.” ? Francis Bacon
Re: hydrogen sources
09/06/2008 12:51 AM
To summarize all of the great links Guest has provided: being a water based plant, algae naturally harbors a relatively high amount of hydrogen as a result of photosynthesis, which researchers are extracting through the introduction of an enzyme. The only drawback at this time is that the said enzyme cannot tolerate the O2 molecules, a bi-product of this extraction process. I would encourage reading the articles provided by the Guest which discuss the numerous ways researchers are addressing this issue.
Thanks for all of the links, Guest.
WGM
There is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance—that principle is contempt prior to investigation.” – Herbert Spencer
09/06/2008 7:16 AM
You can get more information from this link www.oilgae.com.
Suresh Sharma.
09/07/2008 9:58 AM
Hydrogen can be produced quite easily : DC electricity is required , as large a supply
of it as you can get.Water is a Hydrogen/Oxygen compound : H 2 O , two molecules
of hydrogen and one of oxygen.If you apply a DC elecrtric current to water it will
separate into hydrogen gas and oxygen gas.Very volatile.If you separate the two
electrodes and tap off the two gasses separately , and compress it into storage
tanks (compressed gas tanks) one will be oxygen and one will be hydrogen.
steele
Good Answers: 101
09/07/2008 9:38 PM
You're right on this point. The problem is that electrolysis is a highly inefficient, energy intensive process. Using algae or bacteria, which produce their own energy to extract the hydrogen, is more efficient. That's why scientists view this as a more attractive alternative to electrolysis.
Anonymous Poster (2); DVader1000 (1); markalfredsteele (1); WindGenMan (1)
