Well... each switch is different. If you could have as many as you wanted, in a 48 port switch, you could have a maximum of 24 separate VLANs. Why 24? Well that is pretty self-evident, as you need at least two ports to form a VLAN pair.
I have a bunch of SNMP capable Intel Express 100Mb 24 port switches at a server farm I own in Ontario, Canada. These switches can be daisy chained, via their backbones, to form a 7 switch stack. In this configuration I have 168 Ethernet ports. The maximum number of VLANs this stack can support is 128.
Check the docs...
You can have as many VLANs on the switch as its firmware will allow. Whether or not the VLANs have ports assigned to them is a different issue. A VLAN does still need at least two ports to be assigned to it to flow any traffic.
