Previous in Forum: ALTENATOR OUT SIDE THE CAR?   Next in Forum: pyrolysis in diesel engines
20 comments
black, grey and white smoke
09/09/2008 7:52 AM
what is the difference between black, grey and white smoke released by automobiles,and in which cases they are released
Pathfinder Tags: emmisions by automobile
Re: black, grey and white smoke
09/09/2008 9:09 AM
I'm no professional in this area. It appears that white is typically more water vapor, grey seems to what I have seen as oil burning in gasoline engines, typically like oil blowing by worn rings. Black is most often seen in diesel, where combustion is not happening 'just right', so (apparently) the carbon is coming out as more 'metalic' carbon, rather than oxidized as CO2 or CO.
Now hopefully someone will correct me :)
09/09/2008 9:23 AM
black = no pope elected yet
white = pope elected
grey = pope on fire
09/09/2008 5:51 PM
<thud yowl...climbs back on chair>
Good Answers: 11
09/10/2008 8:16 AM
arrrgh, I have to send this to my "big C" Catholic wife.....
Eric
09/10/2008 3:02 PM
I am sorely tempted to give you a GA vote for the humor injected. But I'm too busy ROFLMSAO to do so!!!
Good Answers: 19
09/09/2008 9:37 AM
grey / white smoke in diesels is unburnt fuel vapour caused by a leaky injector or worn delivery valves, black means that the person is using the accelerator as an on / off switch (used to drive a petrol-engined vehicle and has no patience) or possibly a faulty governor, some water vapour looks like white smoke but will clear as the engine and pipe warm up. you didn't ask about blue because that's pretty obvious.
or I could be completely wrong, I put down the spanners in 83.
09/09/2008 10:55 AM
what your engine type? gasoline or diesel and use your smell
in gasoline case :
usualy black and smell like oil burn ; oil burn in your cylinder engine mostly is many oil burn
grey and smell like oil burn ; oil burn in your cylinder engine but is not many
white and your have tears in your eyes ; you have problem with your carbulator
in diesel case :
black, grey ,and white can be a problem with your injector but if you have smell like oil burn your have problem oil burn in your cylinder
in gasoline case open your fire spark if you look many black corosif in spark poin usulaly you change many spark fire cause deat is oil burn in cylinder engine
Good Answers: 38
09/09/2008 12:23 PM
The color, The smell, the taste.
How about reading your text books and really learn, other than asking for a quick answer with no understanding? By looking at all your questions ( all 11 of them )you appear to be a student with little desire to learn how to investigate, read and come to your own conclusions.
Please study and become great at what you do. Then you can come back here and help others with their problems.
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
09/11/2008 2:14 AM
This is Black smoke with black soot on the face of cm 11, from Charsley's motor cycle
09/10/2008 2:44 AM
black smoke = rich man using a lot of extra fuel
Grey smoke = driver has not gotten vecile warned up yet.
White smoke = the a leaking head gasket or crack head either way the driver needs a head doctor.
09/10/2008 7:37 AM
I agree with you dadw5boys GA
Add a little anti freeze to increase the white smoke!
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
09/10/2008 8:17 AM
I'll assume gasoline powered vehicle:
1. Black smoke: fuel related-overly rich fuel/air mixture (too much fuel, not enough air). Caused by a variety of sources; improperly adjusted carburetor, fuel injection problems, too much fuel pressure, incorrectly operating on board computer system, etc.
2. Grey: can be a black/white combination in some few cases (multiple problems;refer to black and white smoke cases); some "grey" is actually blue, which is excessive oil comsumption (bad rings, valve guides/seals, excessive engine wear, etc.). Could be white smoke slightly "tinged" grey; refer to white smoke case.
3. White smoke: coolant loss during combustion; leaking head gaskets, cracked engine components which are cracked to a water passage; coolant is heated and expelled with exhaust. Antifreeze in this case will often "tinge" white smoke "grey". Also gives off a sickly sweet smell at the exhaust.
Perform basic engine tests (compression, cylinder leakdown, running tests, computer/fuel supply and delivery, etc.) tests as needed to find source of problem.
Let us know what you find.
Speak softly and carry a big stick.
Good Answers: 16
09/10/2008 8:20 AM
It seems to me that 74 is the closest to the truth. The following applies to diesel.
White= Coolant
Blue= Oil
Black or Grey Can meen several things and is usualy accompanied by other symptoms like power loss or hihg temps. Listed are only a few usualy seen with EMD medium speed engines;
Overfueling- Governor, or injectors
Low compression- Power assemblies
Air flow problem- Blower, Turbo, Aftercoolers, Turbo Screen.
High Exhaust Back Pressure
OVERLOADED ENGINE
Bad Timing
This is only the most common problems, if you gave some specific engine and application information we could help more.
09/10/2008 8:35 AM
Hell, that is easy, the difference is the color!
09/10/2008 1:37 PM
Black = Gas
Blue/Grey = Oil
"White" = vapor in exhaust = coolant leak somewhere. Not always critical failure, but usually.
PS. "White" could also be residual condensation in system as engine/exhaust is warming up on chiily morning.
Good Answers: 16
09/10/2008 1:56 PM
OOPS, now I see its an automobile in question...
Good Answers: 97
09/10/2008 11:02 PM
What would an exhaust gas analyser be used for
Good Answers: 16
09/11/2008 7:48 AM
Someone who can not analyse the situation without one... But sure would be the quick fix!
Good Answers: 123
09/11/2008 11:38 PM
It is very similar to the alternator. One produces electricity, one produces profits for unscrupulous repair facilities.
Bob
09/14/2008 4:16 AM
Released? Do you mean tailpipe? or the cars themselves burning?
Register to Reply 20 comments
Anonymous Poster (3); bhankiii (1); bob c (1); bwire (1); ca1ic0cat (1); charsley99 (1); dadw5boys (1); DGCYS (1); EnviroMan (1); gsuhas (1); HUX (1); servant74 (1); standarded (1); taufik (1); Tim in Mexico (3); user-deleted-1105 (1)
