I would like to know if 2 inch scd 40 pipe will take the force.Right now I have made a vawt the rotation shaft is 2 inch steel pipe.The mast is scd 40 -4 inch pipe 18 feet above the ground.I have 2 pillow blocks mounted on the 4 inch pipe,One at the top and one 4 feet below the top. The 2 inch shaft that the turbine is conneted to is 4 feet above the top pillow block.The 3 blade turbine is 4 ft 6 in tall and ,each blade is 4ft6in x 53 in long.Everything works fine now.
What I want to do is to make new blades,Same area but hight and width different.
I want the blades to be 8 ft tall and 2 ft tall.My question .Will the 2 in scd 40 pipe hold up the the new diamentions.It will be twice as tall but half as wide.SAME hight above the top of the mast. (4 ft) The reason is higher RPM's
thank you
John
