Previous in Forum: Natural Gas Pricing   Next in Forum: Ferric Chloride Disposal
Screw Feeder & Doctor blade
09/29/2006 10:32 AM
I am looking for contacts of manufacturers of Screw Feedrs for Hot-Melt epoxy adhesive with jacketed hopper and a doctor blade system. The application shall be for drawing epoxy film. Shall appreciate responses.
Re: Screw Feeder & Doctor blade
09/30/2006 2:31 AM
Can you please send us the flow requirement of the Epoxy, Output details, film specifications etc.
Jai Jagat ( Victory to the World - the Slogan of Late Vinoba Bhave)
09/30/2006 3:12 AM
The details are - Screw Feeder &Hopper:
  • Capacity: 120 - 150 kg /hr
  • Single screw feeder with Fish-tail die (500mm wide) at the delivery port
  • Heating max. 80 deg.C through hot water or oil circulation
  • Jacketed Hopper to be integrated with the screw feeder
  • Viscosity :
    • at 25 deg.C - 500 cps
    • at 60 deg.C - 10,000 ~ 16,000 cps
  • Density : 1.2 ~ 1.5
  • Heating controls & uniform heating of the adhesive is a must in the hopper & screew feeder
  • The screw feeder should be equipped with Servo controlled motor and PLC controls
Doctor Blade: The Hot-melt Resin will be directed through a doctor blade system for a uniform casting of epoxy adhesive film at 0.5mm thick and 500mm width. The adhesive will be flown to a carrier film / silicone coated paper and the film speed will be <5 m/min.
  • The doctor blade should have internal heating arrangement
  • a heated bottom plate required
  • blade gap (raising/lowering) to be done through micro-screws and wedges by manual method
We are sure the above information will help you to understand our requirement. Please let us know if you need more information.. Kind regards SamMathai
09/30/2006 6:42 AM
Dear Sam Mathai,
We would like to know if you are looking in for the screw feeder alone or the complete applicator for 500mm width.
If the glue applicator had to be synchronized with any existing system then we need to have detailed information of the existing system
Feel free to contact us for any details:
10/03/2006 10:35 AM
Kindly send me your contact information on "creativebusin@gmail.com".
Good Answers: 16
10/01/2006 10:09 AM
Melfi Technologies provides systems for manufacturing epoxy resins, however we use the Readco Kurimoto continuous blender. It will provide superior mixing and temperature control when compared to a simple screw feeder.
Both our feeder and blender controls are Allen-Bradley based with all setup and data logging on the PLC. Please forward details of your individual ingredients and we would appreciate the opportunity to forward full specifications and pricing.
Regards, Delmar Schmidt
Melfi Technologies Houston
www.melfitechnologies.com
Specializing in Dynamic Weighing Systems for Powder and Bulk Solids Handling
buniprojects (2); Delmar (1); SamMathai (2)
