Previous in Forum: White IR Lamps vs. Red IR Lamps: What's the Difference?   Next in Forum: Why does my room air conditioner trip ELCB?
22 comments
Engine Manufacturer & Model ?
09/12/2008 6:57 AM
Good day
Do anyone have any idea
1. Who manufacture this engine?
2. What country it is currently manufactured in ?
3. Type of engine ? - Hino or Iveco or any other that is manufactured by a 2nd licensed holder company of older technology.
4. Possible year of manufacturing runs ? (e.g. 1980-1988)
5. From the pic - estimated litre size ? ( e.g. 8.3 Litre)
We have this engine partly as seen - it must be built up to be running.
It actually starts and sounds ok - only the turbo have a slight problem.
From the looks and size it looks like a 7.6-8.3 Litre (Turbo & Aftercooled with a SEN injector pump)
If I look at the ASHOK LEYLAND site from India it looks like it originated there but they
responded negatively.
Thank You
Re: Engine Manufacturer & Model ?
09/12/2008 7:01 AM
Heck
I clicked General Discussion but somehow it got here between the editing.
Just do not know how to get it in the right place
Regards
09/12/2008 9:01 AM
Don't panic..it's fine...the vultures will soon find it!
(Maybe it's and prototype KrisDelTM time machine motor?)
Good Answers: 123
09/13/2008 12:26 AM
The time machine was just here. Then it disapeared. When is it now?
Bob
09/13/2008 3:58 AM
Kris just took it for a long weekend back in the 60's
09/13/2008 8:57 AM
"...a long weekend..."
I consider that a bit subjective, considering the manner of conveyance.
Good Answers: 16
09/12/2008 11:02 AM
Interesting... I run into the same problems from time to time.
A couple questions that may help,
  • Is it part of a package (gen set or pump)? If so that might be another research point.
  • Where are the starter, alternator made? Narow your search down.
  • Metric or Standard sizes?
  • Any obvious casting numbers or stampings anywhere?
  • How did you happen across this strainge beast?
09/12/2008 5:01 PM
Hi
As a genset.
Metric
Looks like a Hino engine typo
No plates
Nothing casted on block
Was cheap - very cheap and as a Genset running the minimal hours.
Good Answers: 123
09/13/2008 12:34 AM
You mentioned that it had a Sens injector pump. If you contact them with the injector pump number, they should know what they used that injector pump on, and who they sold it to. Same holds true with the Alternator and starter. but not as exact as the injector pump people.
You might try contacting an injector pump specialty company. they might recognise the engine, or be able to cross reference the injector pump. Good luck.
Bob
09/13/2008 7:13 AM
No marks? Could this be a "clone" (you said 'very cheap')
I've dealt w/ some higher quality 'clones' that the 'donor' parts were a direct interchange...
If you always do what you've always done, You'll always get what you've always had!
09/13/2008 4:00 AM
THAT APPEARS TO BE A BRITISH ENGINE USUALLY USED IN BOATS OR LARGE TRUCKS FOR LONG HAULS.
Good Answers: 25
09/13/2008 8:47 AM
May be Russian. Other components also dont have name plates?
09/13/2008 11:07 AM
What kind of idiot would post his mechanical engineering homework into an electrical engineering forum?
Good Answers: 16
09/13/2008 11:16 AM
Why is it that some people waste time and energy to write BS like this GUEST? The engine is the driver for a generator this man purchased and he is simply looking for a little help from the forum?
If you as a guest cant help, ok... Move on.
Good Answers: 16
09/13/2008 11:28 AM
I realize this may not narow us down completly, but what is the generator information? If a plate does exist.
09/13/2008 7:20 PM
What is the application for this engone now ?
Good Answers: 123
09/13/2008 11:10 PM
What is the electrical output? What voltage, What hertz? These figures may give some clues as to the location where it was manufactured.
I still feel that your best information will come from the fue injector pump. Pump manufacturers make changes to these pumps for every little change, so they will know what used that pump.
Bob
09/14/2008 1:57 AM
BLC,
See if you can read what is printed on the fanbelt. This may help with country of origin. Also see what is printed on the filters after you remove their cans/covers.
LG_DAVE
09/14/2008 4:30 AM
HI
230 KVa, 50Hz
Just landed in the w/shop. Fanbelt and engine Alternator is local. Alot of the parts is local that can fit.
Good Answers: 123
09/14/2008 10:41 PM
You can now rule out the nations that run on 60 Hz. I was hoping that by now you would have shared the numbers on the injector pump.
Bob
09/15/2008 2:03 AM
No Plate - just the cast = SEN
Good Answers: 123
09/15/2008 10:35 AM
That puts another stumbling block in the way. I will go to an injection pump shop and quiz them. Are there any identifying numbers on the starter? It must be matched to an engine design. those # will help. BTW, I am not able to find an injection pump manufacturer by the name of sen.
Bob
09/15/2008 5:57 PM
injection pump looks like a "Bosch" unit
Register to Reply 22 comments
Anonymous Poster (1); BLC (4); bob c (5); dadw5boys (2); EnviroMan (1); LG_Dave (1); sidevalveguru (2); suresh sharma (1); Tim in Mexico (3); user-deleted-1105 (2)
