Hey gang, I can't believe that finding this elusive value is eating my lunch, so I'm looking for some help.
The situation: I'm trying to calculate the amount of temperature rise in a coil of 3/4" copper tube immersed in a solar hot water tank. In order to arrive at the optimum lengths required for the three different coils (incoming cold water make-up to the domestic water heater, the temporarily cold return line from the instant hot water loop, and the hydronic heated floor loop) I must evaluate the heat transfer using the various temperature conditions of tanks & loops. My Major Overkill idiom compelled me to buy a double walled, ss, dairy tank of 600 gal cap and I plan on keeping the water inside it as close to 180-200°F as I can get with my 6, 4 x 10 panels. In the winter here, I expect to see the overnight water temp drop to 120°F (possibly lower, but won't know till we flip that switch) after a couple of cloudy days with normal daily heat extraction.
My problem is that I can not find a good equation for calculating the h-sub-m for the laminar boundary condition undergoing natural convection on the outside of the 3 pumped loops. Aaaarrg. Without this I can't get to "U" to solve my cases. It's largely academic after I get this value. I'm betting that one of you bright folks will have seen a good value, or will know of a way to calculate a reasonable value given that the tank will likely NOT be stratified given the delta T of Min: 30°F and Max 150°F between wall of copper tube and bulk water storage temp in the tank.
Please remember I'm only looking for the external convective film coefficient.
Thanks,
Major Overkill
There are people who make things happen, there are people who watch things happen, and there are people who wonder what happened. To be successful, you need to be a person who makes things happen.. Jim Lovell, NASA Apollo 13 Hero
