Previous in Forum: SQL 2005   Next in Forum: file password
Hello Friends Question about hyper terminal
09/14/2008 3:30 AM
I wants to connect my Alcatel 6024 switch with Hyper Terminal but its not connecting I need Help................
The way I am connecting is
go to start
go to accessories
go to communication
Hyperterminal
switch
com1
bit-9600
data bit-8
Parity-none
stop bit-1
flow cotrol- hardware
Apply
Ok
But still its not connecting and not showing the telnet window
please tell me the right procedure
Re: Hello Friends Question about hyper terminal
09/14/2008 11:56 PM
Download Realterm - it is much easier to use. Whatever is on the serial port will show in the window.
http://realterm.sourceforge.net/
Good Answers: 50
09/15/2008 12:18 AM
Are you connecting through the serial port? You kind of have to unless you get a USB converter.
Are you sure com1 is available, if it shows a choice of com1 and com3, try com3.
Someone may have changed the bit-rate on the switch. If true, you'll have to change the bit-rate on Hyperterm until characters start to show.
Also, isn't there something about hyperterm where you have to save the profile, and then call it and then it starts?
Hope this helps.
09/15/2008 12:31 AM
Hi,
There are 2 reasons why you are unable to connect to hyper terminal.
1. Serail Cable which you have used might not be ok. To check the same, connect the serial cable to your PC. Ensure the com port while selecting through hyper terminal. Then short 2 PIN and 3PIN (using jumper. Then type anything on the terminal should reflect on the screen. If not then there should be some problem with the Cable.
2. Check the Alcatel 6024 switch manual for the Serial communication and ensure same setting are selected from the hyper terminal setting.
I hope this will resolve the issue.
09/15/2008 7:54 AM
Jumper pin 2 and 3 on the RS 232 connector to verify yyou are transmitting and receiving
Learn more, Do more , Be more
Register to Reply 4 comments
Anonymous Poster (1); djacob (1); LG_Dave (1); vermin (1)
You might be interested in: Terminal Blocks
