Previous in Forum: acoustic type flow switch   Next in Forum: Block Diagram of DCS
Zero elevation vs zero suppression
09/14/2008 11:32 AM
Can anyone define where do we use zero elevation and zero suppresion?
Good Answers: 143
Re: Zero elevation vs zero suppression
09/14/2008 11:57 AM
12/29/2009 3:49 PM
simply a bullshit answer
10/02/2008 6:46 PM
The zero refers to the lowest possible output of a device, for example if you have a pressure sensor that is 0 to 15 psi range with a 0 to 10 volt output and you elevate the zero by 5 psi you then have a 5 to 15 psi range pressure sensor with a 0 to 10 V output.
06/19/2010 10:21 PM
Zero elevation is the ability to calibrate an instrument, usually deltr pressure tansmitter so its lower range value is a negative value. i.e. -100 to 0 or -25 to 100 etc.
Register to Reply 4 comments
Anonymous Poster (2); Jack Fisher (1); TVP45 (1)
